Introduction: Kite
this is how I made this kite
supplies include:
glue,
*scissors,
*paper x 2,
sticks,
*tape,
thin, hard thing,
*string,
*spool.
Step 1: Cut
cut two pieces of paper
Step 2: Trim
Stack paper and cut edges so they are the same (one side should be longer than the other) P.s. keep scraps if not using wood/stick.
Step 3: Arrange
line up triangles.
Step 4: Tape
tape together.
Step 5: Trim
line pieces up and trim edges to match.
Step 6: To Continue
If using sticks continue to step#14 skip steps#14 to#23 To not use sticks go to step#14 and continue
Step 7: Meashure and Add
with wood/sticks place corner to corner longways, with 1/2 in on ends and glue.
Step 8: Wait
wait for glue to dry.
Step 9: Meashure Twice
place wood /stick next to the center stick, lining up the stick with the corners, and mark 1/2 in off corner.
Step 10: Repeat
repeat step#9 on other side.
Step 11: Cut
trim wood/stick on the lines and 1/4 down make a circular notch.
Step 12: Glue
notch out glue connecting end to middle of stick in center do not forget to glue to stick in center.
Step 13: Wait
Step 14: Drill
drill holes in wood
Step 15: Craft
use scraps from step#2 to make 8 1 in long peces
Step 16: Tape
Tape the edge of the kite leaving some space on the corners.
Step 17: Tape
take two of the scrap pieces and tape together so the whole thing is covered in tape Repeat four times.
Step 18: Tape
take one piece of stuff made in step 16 and tape it's ends together repeat four times
Step 19: Tape
tape over paper of things made in step#17
Step 20: Insert and Tape
insert things made in step#18 into kite on corners and tape over the seal
Step 21: Tape
tape over top of all things inserted on step#19 and cut tape to show holes.
Step 22: String
string thread through all ends and tie off
Step 23: Meashure and Tie
measure four about 1 Ft long pieces of string and tie one end of the string. trim if necessary
Step 24: Tie
tie one string end to each corner.
Step 25: Tie
tie string onto middle but leave on the spool.
Step 26: Done
ready to fly!
