Introduction: K'nex - Colt Python Instructions
Hey guys and today I bring you instructions for the Colt Python. It is a revolver that was used in several police forces but it did eventually fall out of service due to the need of semi automatic pistols. Its not my own design since I did follow pictures from Blue Mullet 2.
Good Points
· Very Realistic
· Comfortable Hand Grip
· Good Iron Sights
. You Can Have The Barrel At Any Length
Bad Points
· Doesn't Shoot Because It's Just A Model
· Uses Quite A Lot Of Cut Pieces (See Parts List)
· The Whole Gun Is Slightly Flimsy
Specifications For A Real Colt Python
· Designed - 1955
· Number Built - Unknown
· Ammo - .357 Magnum
· Rate Of Fire - 6 Rounds Per Minute
· Powered - Double Action
· Magazine - 6 Round Magazine
· Range - Between 25 and 50 yards
In Call Of Duty: Zombies, the Python appears in every single map for Black Ops and all Black Ops II maps apart from Mob Of The Dead and Buried where it is only available from the Mystery Box for 950 points. It has a one shoot kill up to round 10. Speed Cola is strongly recommended to reload each new bullet into the cylinder. When it is Pack-A-Punched for 5000 points it becomes the "Cobra" where you get more damage, more ammo and a speed reloader. In BO II with Double Tap 2.0 it will have one shoot kill up to round 22 but you can still go for headshots even after it has lost its one shoot kill.
Also check out my other creations and instructions
https://www.instructables.com/id/Knex-1975-CZ-75-Instructions/
https://www.instructables.com/id/Knex-Biplane-Instructions/
https://www.instructables.com/id/Knex-1976-MP5K-Instructions/
https://www.instructables.com/id/My-Knex-Weapons-Of-2013-2014/
https://www.instructables.com/id/Knex-James-Bond-Helicopter-With-Saws/
https://www.instructables.com/id/Knex-1979-SPAS-12-Instructions/
https://www.instructables.com/id/Knex-Galvaknuckles-Instructions/
Step 1: Parts List
If you have any trouble or need more pictures just leave a comment and I will get back you ASAP. I strongly advised you to collect all the pieces before you start building. Also I have added a few notes throughout this instructable to make it more easier to understand something if you run into any difficulty.
Green Rods - 61
White Rods - 21
Blue Rods - 1
Green Connectors - 4
White Connectors - 3
Blue Connectors - 2
Yellow Connectors - 22
Red Connectors - 5
Light Grey Connectors - 1
Dark Grey Connectors - 1
Orange Connectors - 12
Tan Connectors - 1
Tan Connectors (with the little tab cut off) - 2
Y Shape Black Connector - 21
Orange 86mm Flexy Rod - 1
White Connectors - (cut, see step 3) - 6
Blue Connectors - (cut, see step 2) - 1
1.9cm cut Rods - 8
3.2cm cut Rods - 6
Hinge Black Half - 5
Hinge Blue Half - 5
Black Wheel 25mm Open Centre - 6
Blue Spacer - 2
Total - 197
Step 2: Handle & Trigger
Step 3: Magazine Well
Step 4: Barrel
Step 5: Done
Well done you made it to the end I do hope you have enjoyed building it
Zombie Quotes About The Colt Python
" A Python it many not be venomous but it'll sure leave a mark"
"I will take great care to ensure every bullet finds it's target"
"Oooh a Python is it wrong now to consider myself a proficient snake charmer"
Thanks for building it please leave a comment in the box below and subscribe
