Introduction: K'nex Semi-Automatic/Single Action
Pull Back Slide
True Trigger
6 -rd magazine of skortest connectors
extended barrel
able to shoot yellow sticks about 10 meters accurately with 4 rubber bands though
sorry guys, but you have to pull back the slide everytime to fire, you can replace some of the white snowflake ones not in the barrel with the blue piece useed in step 4
True Trigger
extended barrel
Step 1: Pieces Required
these are the pieces you need along. three special black connector pieces are not listed though but are not nexessary as they are used to make the sights.
Step 2: Making the Stock
The end of the stock can be made anyway you like but i find that this is the most comfortable ...your choice
Step 3: Constructing the Barrel
This is the barrel. The extra orange connector is to stop the ammo from falling out the barrel if you are pointing down
Step 4: Completing the Barrel
try to figure out the rubber band placement right now until i add more info. you need to add two blue connectors to the front and two white sticks at the back. the blue part is the trigger and the big blue thing connects the barrel with the stock.
Step 5: Making the Barrel Extension
this is not a required part of the gun but i find it helps improve accuracy and when using higher tension rubber bands as the rounds will tend to fly out of the barrel very oddly without it
Step 6: Making the Magazine
you need to cut the two grey pieces so a green connector can fit through the top easily
Step 7: Making the Handle
the first pictures yellow connectors going down the middle are the ones that connect to the barrel at the connector that connects the stock and barrel
Step 8: Making the Scope
more to come to find out how to attach it
