Introduction: K'nex Tablet Case
About: Hello! I'm Nerfrocketeer, also known as Nefrock', Nerf, or NK. I am an avid fan of Nerf wars, engineering, and animal activism (but no I don't go overboard). Thank you for A MILLION views (woah!) and making me…
Congratulations! You are the proud owner of a brand-new tablet! You just picked it up from the store, mind buzzing with all of the fun technological times ahead! The smooth, sleek lines and superior interface of your new tablet have you staring in awe every time you pick it up.
You want to take it to work, to show off your latest purchase to your coworkers. There's a big meeting scheduled, and a tablet like this will surely be a big help in the conversation.
There's only one problem... You forgot to buy a case for it!
It's too late to go back to the store now! How can you take your tablet to work when there's nothing to make it look unique?! Forget the smooth, sleek lines that had you in awe earlier! You need some COLOR!!!Maybe taking it to work isn't such a great idea... Shucks...
Why so glum? There's a simple solution to your problem! Remember that huge box of K'nex that you bought the kids last Christmas? It can save your dreams of technological fun!
With the K'nex housed in that box, you can quickly build a high tech, super unique case that will have all your coworkers staring in wonder!
Hurry up and grab that box! You have some building to do!
NOTES: This case is optimized for the iPad Mini, an 8" screen tablet. Tablet sizes may vary. Furthermore, this case does not guarantee protection from damage, in which case the author of this Instructable cannot be held responsible. Thank you.
Step 1: Pieces
To make the K'nex Tablet Case, you will need:
-23 White connectors
-1 Blue connector
-15 Yellow connectors
-20 Grey connectors
-6 Red connectors
-4 Light grey connectors
-3 Orange diagonal "Y" connectors
-2 Purple loop connectors
-Two "Y" connectors
-2 Black caps
-4 Blue separators
-89 Green rods
-45 White rods
-1 Green bendy rod
Step 2: Backing
Take five white connectors and connect them using green rods. Repeat to get two rows.
Make a third row with a blue connector in place of a white connector on one end. Make sure it is facing the same way as in the pictures! We use the blue connector to allow the camera of the tablet to "see" through the back of the case.
Arrange the three rows as shown and connect them using green rods.
Step 3: Edges
Take two grey connectors and slide them together as shown. Repeat to get five pieces. Connect the five pieces using green rods.
Repeat the above process to make a row of three grey 3D connectors.
You will also need to make a row with two grey 3D connectors and a yellow connector.
Finally, you will need a row of five yellow connectors connected by green rods.
Attach the four different edges to the backing (Step 2) exactly as shown. The reason why they are all different is to allow them to perform different functions such as holding in the tablet, allowing it to be easily inserted and removed, and allowing camera use.
Finish of the edges by adding four red connectors and filling in all spaces with white rods exactly as in the last picture.
Step 4: Restraint Nubs
Restraint nubs will keep your tablet from falling forward out of the case.
Attach a light grey connector to a white rod as shown. Repeat to get four pieces.
Next, add the four pieces to the rest of the case as shown. Make sure they are facing the same direction as in the pictures!
Step 5: Insertion Slot
The insertion slot helps make use with your tablet easier. You can simply unhook one end, open the green bendy rod, and slide your tablet in or out.
Add two white rods to the top corners of the case as shown.
Next, slide one purple loop connector, two blue separators, and one black cap onto each white rod.
Then, attach two "Y" connectors to a green bendy rod, taking care to ensure they are facing the same direction.
Attach the green bendy rod to both of the purple loop connectors in the corners. When connected the "Y" connectors should fit into openings in the backing of the case.
Step 6: Back Stand / Screen Protector
The back stand / screen protector helps you use and protect your tablet. When attached to the back of the case it props up your tablet at roughly a 75-degree angle, to make viewing easy. When attached to the front, it shields your tablet's screen from possible damage.
To build, take three white connectors and connect them using green rods. Repeat to get three rows total. Connect the three rows using green rods.
Next, take three yellow connectors, and connect them using green rods. Repeat to get three rows total. Add the three rows of yellow connectors to the three rows of white connectors as shown.
Finally, add two red connectors to the bottom two corners, and fill in all spaces using white rods.
To make it attachable to the rest of the case, add three white rods to the top of the piece, and add three diagonal "Y" connectors to the end of each rod.
Step 7: Attaching the Back Stand
To attach the piece made in step 6 to function as a back stand, insert the diagonal "Y" connectors into the top of the case as shown. The stand should fit snugly into the back and be evenly between both sides of the case.
Step 8: Inserting Your Tablet
To insert your tablet, simply unhook one end of the green bendy rod from step 5, and slide in your tablet. It helps to make sure the camera is over the opening created in step 2. Once your tablet is in the case, close the insertion slot once more. Your case is now in use!
Step 9: Your K'nex Tablet Case Is Complete!
Congratulations! You now have a working K'nex tablet case on your hands! Now you can take your tablet with you without having to bring loads of extra gear! Now the big meeting will be fine, and maybe even fun! The K'nex tablet case is a definite conversation starter!
Have "fun" at work! Now that you can bring your tablet case, there's nothing you can't accomplish!
