Introduction: Knitting Lessons: Cast on Techniques
All knitting starts with casting on. This creates loops on the needle which will become the first row of stitches. Here I present four cast on techniques which are the most commonly used.
These techniques include:
Single Cast On
Longtail Cast On
Knitted Cast On
Cable Cast On
I recommend learning the Single Cast On and Longtail Cast On techniques first. The longtail is my favorite; once you get the hang of it it is super easy and makes a nice edge. I would wait to learn the knit stitch before you learn the Knitted Cast On and Cable Cast On. It is much simpler once you are proficient at the knit stitch.
I suggest using wooden needles when learning how to knit.
For more knitting tutorials visit my page: Carleyy.
Step 1: Single Cast On
- Start by making a loop with the yarn.
- Bring the yarn through the loop, creating another loop with a knot at the end
- Slide slip knot onto needle. Pull yarn to tighten knot
- Wrap the working yarn (yarn connected to the ball of yarn) around your thumb so you have a loop around your thumb.
- Bring the needle under and up through the loop around your thumb
- Remove your thumb from the loop and pull the yarn
- Continue from step 2 until you have desired number of stitches casted on
Step 2: Longtail Cast On
- Drape the tail over your thumb and pointer finger on your left hand.
- Catch it in between your pointer and middle finger.
- Catch the yarn connected to the ball against your palm with your pinky and ring fingers.
- Take the needle in your right hand. Place it on top of the yarn between your thumb and pointer finger.
- Draw the yarn towards you with the needle. You should see a loop of yarn around your thumb.
- Bring the needle under the outer piece of yarn next to your thumb and up through the loop.
- Bring the needle back towards your pointer finger.
- Bring the needle over the yarn connected to your pointer finger and then under back towards the thumb.
- Drop the head of the needle back down through the loop around your thumb.
- Release your thumb from the loop and pull the yarn.
- Repeat from step 6 until you have the desired number of stitches casted on.
Step 3: Knit Cast On
- Make a slip knot and put it on your needle. Hold this needle in your left hand and take the second needle in your right hand.
- Pass the needle in the right hand through the loop on the left needle and bring the right needle under the left needle.
- With your left hand, wrap the working yarn around your left hand needle.
- Bring the right needle back through the loop on the left needle.
- Now you have a loop around your right needle. Turn the loop and drop it on to the left needle and release the right needle from the loop .
- Pull the yarn and you have two stitches casted on.
- To continue, repeat from step 2.
Step 4: Cable Cast On
- For the first two stitches, use instructions for knitted cast on.
- Once you have two stitches casted on. Take your right needle and put it in between the two stitches by bringing it under the left needle and through the yarn that connects the two stitches.
- Wrap the working yarn around the right needle.
- Bring the right needle back through the loops.
- Pull the yarn. You should have two stitches casted on.
