Introduction: Kylo Ren Mask
About: Instagram @sunny_naguri @boomerangstudios
If you're a Star wars fan and are awaiting to watch the new movie, then this is the perfect thing to make, your very own Kylo ren mask/helmet.
Step 1: You'll Need:
1. Craft Foam
2. Paper
3. Reference Images/Template
4. Box Cutter/Xacto Knife
5. Masking Tape
6. Elastic
7. Velcro
8. Contact Cement (Rubber Cement)
9. Mod Podge
10. Spray Paint (silver and Black)
Step 2: Cutting Out the Basic Template
Cut out the basic template out of card/paper and if it fits your face, go ahead! trace it onto craft foam and cut it out the same way you cut out the template.
Step 3: Cutting Out the Pattern
Now, get on to the pattern on the mask. Cut this pattern on a different sheet of craft foam, not the one we used in the previous step. Don't stick the pattern onto the mask yet. Still have to shape the mask before adding the details.
Step 4: Making the Bottom Part of the Mask
Cut the pieces out of craft foam as shown in the first picture. Stick the second piece onto the first one and then shape it. After you've done that, make blocks with foam and stick onto second piece. Then, stick the third piece onto the blocks.
Cut out the shapes in the last image and keep them aside, we'll get to it in a later step.
Step 5: Sealing and Painting
Seal all the pieces with layers of mod podge and let it dry overnight. Once that is done, Color the pattern silver and the rest of the pieces black.
Step 6: Shaping the Foam and Sticking the Silver Pattern.
Step 7: Attach the Bottom Pieces and Add Velcro and Elastic.
Step 8: Covering the Eye Hole
Cover the eye hole with a semi transparent/see through black cloth.
Step 9: Here Are Some Pictures.
coming up next: Diy Tie fighter
Please do show your support by voting for this instructable at the sci-fi contest.
