Introduction: LED Arduino Night Light
About my project: This is my LED Arduino Night Light. This is my project, I made a night light using Arduino and I add paper to make it look nice.
I follow the link of making LED: https://www.instructables.com/id/How-to-Blink-LED-Using-Arduino//
LED- x1
Jumper Wire- x3
Resistor- x1
Paper(color and non color)- x6
Power bank- x1
scissors- x1
Pen(color and non color)- x5
Double-sided tape- x1
USB cable- x1
Arduino Leonardo- x1
Breadboard- x1
Step 1: Prepare the Material You'll Need
LED, Jumper Wire, Resistor, Paper(color and no color), Power bank, scissors, Pen(color and no color), Double-sided tape, USB cable, Arduino Leonardo and breadboard
Step 2: Put the LED
Put the LED on the breadboard like the picture
Step 3: Connect the Jumper Wire
Connect the Jumper Wire from the same line as long leg to your output (my output is 12)
Step 4: Put the Resistor
Connect the resistor from the same line as the short leg to B-48
Step 5: Connect Another Jumper Wire
Connect another jumper wire from the same line as the resistor to the negative of the breadboard
Step 6: Connect the The Final Jumper Wire
Connect the final jumper wire from the negative of the breadboard to the GND
Step 7: It Should Look Like This...
Step 8: Cut and Stick the Paper
You can do whatever you want with the paper as long as it covers most of your wire and board. ( for me I just trace a free to use side girl picture and draw out the character that I like)
Step 9: Enter the Code
To upload the code into Arduino, you'll need to attach your Arduino broad with pc using the USB cable
This link is for the code that I used:
https://create.arduino.cc/editor/apple_697/1439076...(I change the delay time and the output)
Step 10: You Are Done!
After you upload the code into Arduino, you can connect the USB cable to the power bank for the look
