Introduction: LED Hexagon Wall Clock
The HexaClock is a hexagon-shaped LED matrix with each pixel also in the shape of a hexagon! There are 127 individual RGB pixels ready to pour some colors onto your wall.
3D Printed parts
  • HexGrid (white)
  • LedBase (black)
  • PcbCover (black)
  • RearBase (black)
  • WallHook (black)
Electronics
  • custom PCB - order at your favorite PCB manufacturer
  • ESP8266-12E/F LINK
  • FTDI programmer + wires
  • 2x tact switch 5mm
  • PR photoresistor 5537 or similar (~20-50kOhm bright resistance)
  • C2A THT capacitor 220uF 16V
  • F2 SMD 1808 5A fuse + fuse holder
  • a bunch of 90° angled 2.54mm male "dupont" pins
  • J2 jumper 2.54mm
  • R1B 6.8kOhm*
  • R2 10kOhm*
  • R3 10kOhm*
  • R4 10kOhm*
  • R5 10kOhm*
  • R6 10kOhm*
  • C1B 100nF*
  • U2 AMS1117-3.3 voltage regulator*
  • 5V WS2812B 60led/meter addresable LED strip approx 2.2m long (total 127 leds)
  • Power jack 5.5/2.5mm socket
  • ~2m of 18AWG wire or similar
  • ~1m of 26AWG wire or similar
  • Power supply 5V/5A DC 5.5/2.5mm power jack
  • (if needed) Power cord extension 5.5/2.5mm power jack
*presoldered on the custom PCB
Screws
  • M2x5 x30
  • M3x8 x6
  • M3x5 x4
Tools & Others
  • 3D printer
  • soldering iron with a small tip
  • solder
  • wire stripper
  • a little alcohol for cleaning
  • thin shrinking tubes
Step 1: 3D Print the Parts
There are only 5 parts to be printed. You need a printer with at least 225x200mm printbed. For the HexGrid part, which is the front of the clock, it is probably the best to have a glossy flat surface like glass or PEI.
  • HexGrid (white)
  • LedBase (black)
  • PcbCover (black)
  • RearBase (black) /w supports
  • WallHook (black) /w supports
Print settings
I printed all the parts with ABS*, 100% infill, supports off (except for the RearBase and WallHook parts) and heated bed.
I utilised my good, old and indestructible Prusa i3 MK2S printer.
* The LED strip and the PCB may get a little warm, so I recommend to use ABS. I haven't tested with PLA.
Step 2: Divide and Prepare the LED Strip
Divide
Cut the strip into the following lengths:
  • 2x 7 LEDs
  • 2x 8 LEDs
  • 2x 9 LEDs
  • 2x 10 LEDs
  • 2x 11 LEDs
  • 2x 12 LEDs
  • 1x 13 LEDs
Make sure that:
a) you cut the strip only on the white markings in the middle of the solder pads!
b) your cut pieces are continuous, i.e. there are no solder joins (solder connection) between separate strips*
*Usually the long strips are combined from shorter length strips e.g. 5m = 5 x 1m strips soldered together. If your cut pieces have these solder joins, they may be too thick to fit the casing
Remove double-sided tape at the tips
Uncover about 5mm of the strip pieces at both ends, be careful not to break the copper tracks. I did it with an exacto knife. We are going to solder the pieces on the bottom side. Clean the pads from any glue and debris with alcohol.
Cover the pads with solder
Melt some solder on the pads on both ends of the cut pieces. Do it only on the bottom side of the strips.
Step 3: Stick the Cut LED Strips
Remove the double sided tape cover and stick the cut pieces to the flat surface of the LedBase. Orient the LedBase as on the first picture. Make sure to switch the directions as described on the photo. Try to be very precise. The strips should be parallel and centered relative to the base
Step 4: Solder the Strips Together
Prepare the wires
Cut wires in the following lengths:
  • 12x 18AWG* 63mm
  • 12x 18AWG* 45mm
  • 12x 26AWG 54mm
Strip ~2-3mm of insulation at each end.
Tin the tips of the wires.
*It's very important that your power wires are thick enough! The LEDs consume a lot of current - thinner wires may cause overheating and are a fire hazard!
Solder the wires
This is probably the harders part. Flip the LedBase and solder the wires to the strips. Follow the photos to do it in the correct order. The middle wire is the data line and thus it's thinner. The outer wire is the longest (63mm) and the inner is the shortest (45mm). 5V must be always soldered to 5V and GND to GND, pay attention to that.
Step 5: Assemble the PCB
Use the gerber files and optionally the Pick&Place and BOM files to manufacture the PCB. I ordered my PCB with only some of the components presoldered, as I had had the rest of them laying around in my workshop. As soon as you get your PCB manufactured, solder any missing components.
Step 6: Assemble the Circuit
Connect the PCB to:
  1. The power socket. Make sure to use thick wires (18AWG) as they are going to handle high currents.Check the polarity of your power supply. Solder 5V to 5V and GND to GND!
  2. The LEDs. 5V to 5V (thick 18AWG), GND to GND (thick 18AWG), Data to DI (Data in).
  3. The photoresistor. I strongly recommend adding shrinking tubes to isolate the loose photoresistor "legs". It can be soldered via thinner wires, the direction doesn't matter.
Once again make sure that that all connections (especially power wires) are soldered properly.
Step 7: Assemble the Body
Assemble the LED Hexagon Wall Clock. Screw together all the 3d printed elements and the electronics (see pictures). Screw the soldered power connector in. Place the photoresistor in the hole and secure it with hot glue from the inside.
Step 8: Install the Software
Prepare the FTDI, connect it to your PC via USB cable. Connect the other end to the PCB following the pinout on the picture.
To upload the program onto your MCU follow the instructions on my GitHub repository.
Step 9: First Run
Set up your LED Hexagon Wall Clock using the instructions on my GitHub repository.
