Introduction: LED TUBE LIGHT (AC)
About: Now I am a retired person, who enjoys life and making small things to pass the time keep myself busy.
INTRO.
My friend Justin, wanted my help to make a LED Tube Light, so this is the result for all of you to see.
The tube light is a row of LED's which runs on 110 or 220 volts AC, just like your ordinary Fluorescent Tube Light.
Step 1: STEP-1
List of parts required.
100 pieces or more of Very Bright White LED's of 5mm size.
1-or more Non Polarized Capacitor .33uF to .47uF rated 250v to 300 volts for ----110v AC
1-or more Non Polarized Capacitor .22 uF rated 400 volts -for 220 volts for AC
1 or more Resistance of 1k -1 watt for ----110v AC
1 or more Resistance of 1k - 1/2 watt for ----220v AC
2 inches width and 4 feet long PVC concealed wiring rigid batten.
On off Switch, wire, wall plug, solder etc.
Step 2: STEP-2
In this Step take a 2 inches width and 4 feet long PVC concealed wiring batten.
Fix two rows of 15+15 LED's at a gap of 1 inch.
This 30 LED make one segment.
Fix 3 SEGMENTS of 90 LED's as shown in the Photographs.
Follow the Circuit Diagram in detail.
The gap between the LED's should be 1 inch so as to cover the 4 feet of PVC batten.
The 3 segments should be connected in parallel to the house AC outlet. (110 volts)
Put an on-off switch before connecting to the house outlet.
Your Tube light is ready.
Switch it on and enjoy the soft light.
Step 3: STEP-3
This circuit is for them who have 220 volts AC as their house supply.
I added this step for them.
