Introduction: LEDs and Wood
Made something from nothing useing stuff that would other wise be garbage
Recycled things , dremel , peice of wood your choice,
Step 1: Leds and Wood
Puting your outline on the wood spray adhesive on peice of wood then with proper placement push it down
Step 2: LEDs and Wood
Used bits to go around the out line the deeper the better and easier to cut out later then used 60 120 and 220 sand paper .Once it looks like you want it to then proceeded to cut it out. I used a band saw not recommend , scroll saw or jig saw is . After that I found a old battery aa box with switch hooked up lights then found more old junk laying around that wasn't being used .The black base is from a candle holder cut it with cutting wheel with dremel (caution wear safety glasses and gloves ) drilled out middle to match other piece of flexible metal tube ran wires through it out a nut on and placed battery box underneath with hot glue and glued the lights on back . I wanted to make something you can't just go out and buy for my Dad . Thanks and hope to make more things out of recycled things and post them here for
Mikesart81 thanks for reading.
