Introduction: LEGO CAR CREATIONS
HI EVERYBODY! I AM DENSITY AND I AM 14 YEARS OLD. I AM A BIG FAN OF INSTRUCTABLES AND LEGO SO THIS TIME I WILL SHOW YOU HOW TO MAKE LEGO CARS. YOU DO NOT HAVE TO USE THE EXACT SAME PIECES. SOME MIGHT BE HARD TO FIND. IF YOU DO NOT HAVE THE REQUIRED PIECES, SUBSTITUTE THEM FOR OTHER PIECES THAT CAN REPLACE THE MISSING ONES. YOU CAN ALSO CHANGE THE COLOUR OF THE PIECES. I MADE 2 SIMILAR DESIGNS TO SHOW YOU HOW YOU CAN CHANGE THE APPEARANCE USING THE SAME PIECES. THESE ARE SIMPLE DESIGNS AND THE CARS CAN BE MADE INTO A COLLECTION. I SUGGEST YOU READ THROUGH THE INSTRUCTABLE BEFORE YOU BEGIN TO SEE WHAT PIECES YOU NEED AND WHICH ONES CAN BE REPLACED. YOU CAN ADD THINGS ON THE CAR TO MAKE IT LOOKER COOLER. I HOPE THE INSTRUCTIONS ARE SIMPLE AND EASY TO UNDERSTAND. ENJOY AND HAVE FUN.
Step 1: MATERIALS
THESE ARE THE LEGO PIECES YOU WILL NEED. REMEMBER IF YOU DONT HAVE ALL OF THEM, FIND A REPLACEMENT PART.
- X1 4X4 PLATE
- X5 2X1 RADIATER GRILLS
- X1 1X2 W. 1 KNOB PLATE
- X7 1X1X2/3 ROOF TILE
- X3 1X2 PLATES
- X4 TIRE SURROUNDERS
- X4 TIRES
- X2 2X2 BEARING ELEMENTS
- X2 1/3 W. BOWS
- X4 1X1 ROUND PLATE
- X1 1X4 FLAT TILE
- X1 2X6 PLATE
- X1 2X3 PLATE
- X1 2X2 PLATE
- X4 1X2/1X4 ANGLED PLATES
- X2 1X2 FLAT TILES
- X1 4X4 PLATE
- X3 1X2 PLATES
- X4 TIRES
- X2 1/3 W. BOWS
- X1 1X4 FLAT TILE
- X1 2X6 PLATE
- X1 2X3 PLATE
- X1 2X2 PLATE
- X2 1X2 FLAT TILES
Step 2: DESIGN 1:BASE OF CAR
PLACE THE 4 ROUND PLATES ON EACH CORNER OF THE 4X4 PLATE
PLACE THE 2X6 PLATE ON TOP OF THE 4X4 PLATE SO THAT IT IS STICKING OUT EVENLY ON BOTH SIDES.
PUT THE BEARING ELEMENTS UNDER THE STICKING OUT PART OF THE 2X6 PLATE.
Step 3: TAIL
PLACE THE ROOF TILES ALONG THE ANGLED PLATE (THE 1X4 SIDE). TRY AND MAKE THE LIGHTER COLOURED ROOF TILES GO ON THE OUTSIDE TO MAKE IT LOOK LIKE TAIL LIGHTS. PLACE THE ANGLED PLATE ON THE STICKING OUT PART OF THE BEARING ELEMENT AT THE BACK.
Step 4: HEAD
PLACE 2 OF THE ROOF TILES ON THE OUTER SIDES OF THE ANGLED PLATE.
PLACE THE 1X2 PLATE BETWEEN THE 2 ROOF TILES.
ADD ONE OF THE RADIATER GRILLE ON THE 1X2 PLATE.
PLACE THE ANGLED PLATE ON THE STICKING OUT PART OF THE BEARING ELEMENT AT THE FRONT.
Step 5: BODY 1
PUT THE 1 KNOB PLATE ON ONE SIDE OF THE 2X3 PLATE.
NEXT TO IT, ADD A RADIATER GRILLE.
THEN ADD A 1X2 PLATE AT THE OTHER SIDE.
PLACE THE 2X3 PLATE ON THE 2X6 FLAT PIECE SO IT GOES OVER ONTO THE ANGLED PLATE.
Step 6: BODY 2
PLACE A RADIATER GRILLE ON ONE SIDE OF THE ANGLED PLATE.
ADD A 1X2 FLAT TILE NEXT TO IT.
DO THE OPPOSITE TO THE OTHER ANGLED PLATE (IMAGE 2).
PLACE THE ANGLED PLATES ON BOTH SIDES OF THE CAR (IMAGE 3).
Step 7: BODY 3
ADD THE 2X2 PLATE ON THE 2X6 FLAT PIECE.
ADD A ROOF TILE ON THE 1 KNOB PLATE (IMAGE 2).
Step 8: BODY 4
ADD THE TIRE SURROUNDERS ON THE CAR.
Step 9: WINDSHEILD
ADD THE 2X2 BRICK BETWEEN THE 2X2 PLATE AND THE 1 KNOB PLATE.
ADD THE 1X2 PLATE ON TOP OF THE 2X2 PLATE.
ADD THE 2 BOWS SO THAT IT LOOKS LIKE IMAGE 2.
ADD A RDIATER GRILLE ON TOP OF THE 1X2 PLATE (IMAGE 3).
Step 10: SPOILER AND AIR SCOOP
YOU CAN ADD AN AIR SCOOP AT THE TOP OF THE CAR. IT IS USED TO DIRECT AIR TO THE ENGINE. YOU CAN MAKE IT OUT THE PIECES IN IMAGE 2 AND 4 OR EVEN AN ENGINE PIECE.
PLACE THAT PIECE ON THE 2X2 BRICK.
Step 11: TIRES
ADD THE TIRES TO THE BEARING ELEMENTS.
Step 12: FINISHED DESIGN 1
YOU ARE DONE DESIGN 1. NOW TRY DESIGN 2 AND SEE WHICH YOU LIKE BETTER.
Step 13: DESIGN 2: BASE AND TIRES
THIS IS THE SECOND LEGO CAR DESIGN.
ADD 2 ROUND PLATES ON ONE SIDE OF THE 4X4 PLATE.
ADD THE 2X6 PLATE ON THE 4X4 PLATE SO THAT IT IS EQUALLY STICKING OUT ON EACH SIDE.
ADD RADIATER GRILLES NEXT TO THE ROUND PLATES.
ADD 2 TIRE HOLDERS UNDER THE STICKING OUT SIDES OF THE 2X6 PLATE.
ADD THE TIRES.
PUT 2 FLAT TILES NEXT TO THE RADIATER GRILLE.
ADD TO ROUND PLATES NEXT TO THE FLAT TILES (IMAGE 3).
ADD THE TIRES.
Step 14: TAIL
PLACE THE ROOF TILES ALONG THE ANGLED PLATE (THE 1X4 SIDE). TRY AND MAKE THE LIGHTER COLOURED ROOF TILES GO ON THE OUTSIDE TO MAKE IT LOOK LIKE TAIL LIGHTS. PLACE THE ANGLED PLATE ON THE STICKING OUT PART OF THE TIRE HOLDERS (IMAGE 2).
Step 15: HEAD
PLACE THE 1X2 FLAT PIECE BETWEEN THE 2 ROOF TILES.
PLACE THE ANGLED PLATE ON THE STICKING OUT PART OF THE TIRE HOLDER AT THE FRONT.
Step 16: SPOILER
THEN ADD A 1X2 FLAT PIECE AT THE OTHER SIDE.
ADD THE 1X4 FLAT TILE OVER THE 1X2 PLATE.
PUT A ROOF TILE ON THE 1 KNOB PLATE.
PLACE THE 2X3 ON THE 2X6 PLATE SO IT GOES OVER ONTO THE ANGLED PLATE.
PUT THE 2X2 PLATE ON THE 2X6 PLATE.
Step 17: WINDSHEILD AND AIR SCOOP
ADD THE BOWS OVER THE 2X2 PLATE.
PUT A 1X2 FLAT PIECE OVER THE 2X2 PLATE.
ADD THE RADIATER GRILLE OVER THE 1X2 PLATE.
PLACE THE 2X2 BRICK BETWEEN THE 2X2 PLATE AND THE 1 KNOB PLATE.
Step 18: FINISHED DESIGN 2
THIS IS THE FINISHED SECOND DESIGN. THANK YOU FOR TAKING YOUR OWN TIME AND CHECKING OUT MY LEGO CAR CREATIONS. I HOPE IT WAS EASY TO UNDERSTAND AND THAT IT WAS FUN. THERE WILL BE MORE DESIGNS COMING SOON. PLEASE COMMENT ON WHAT YOU THINK AND HOW I CAN IMPROVE IT. ALSO CHECK OUT MY LEGO USB AT: https://www.instructables.com/id/LEGO-USB-2/ .
AND MY OTHER CAR DESIGN AT:
https://www.instructables.com/id/LEGO-CAR-CREATIONS-2/
THANK YOU VERY MUCH AND ENJOY.
