Introduction: LEGO Game Boy Transformer Official Parts List and Instructions
About: This is the official Instructables profile of Baron Julius Alexander von Brunk, an eccentric multimedia artist in New York City! Baron von Brunk is widely known as a master LEGO craftsman whose work has been p…
Update 12/4/2012 -As pointed out by a fan, there are two pieces accidentally left out of the instructions! When reverse-engineering my model to make the instructions, I forgot to add two 1x2 black (or grey) plates. Please refer to step 2 to see the notations of where to add them. You can use any color plate to use as the missing pieces, so long as they're 1x2; they go underneath the 1x2 Technic brick with two holes on the elbow section of both arms (refer to step 2 to see the notations).
Howdy folks! Baron von Brunk here with the long-anticipated step-by-step tutorial how to create the famous LEGO/Transformers/Game Boy mashup recently made by me. Due to the overwhelming amount of fan suggestions, I've painstakingly reverse-engineered this item and created a series of pictures with every step to make your own clones, based off the parts list!
Within this guide you'll see a master list of parts for both Domaster and Tetrawing, a series of instructions on how to assemble each body section, how to make the weapons, how to transform both robots, obtaining the labels for the Tetris/Nintendo logos, and some encouragement on how to make your own variations with different colors and/or sizes!
I'd like to thank a fella by the name of GW on MOCpages for his support especially, as he's the first one to spread this project across the internet which made it go viral. Check out all of his custom creations and show him plenty of respect! Next I'd like to thank all of you loyal fans -- or Brunkamaniacs -- on the realms of Facebook, Twitter, Tumblr and DeviantArt -- to whom showed me great appreciation and positive feedback! Fans of video games, LEGO pieces and Transformers can finally unite as one!
-Baron von Brunk
P.S. - I now have this entered on CUUSSOO, so if you're interested in having this potentially mass marketed, be sure to log in and support!
LEGO® and the brick configuration are property of The LEGO Group, which does not sponsor, own, or endorse this custom creation.
Step 1: Domaster (Game Boy) Parts List
Here's the link for a complete list of Domaster's parts, with every type, color, and quantity listed. This list is just for the Game Boy itself, and not the Tetris cartridge. This list also includes the weapons (battery blasters). This was generated by Ldraw software, with the parts library provided by www.peeron.com. To obtain parts in bulk order or in custom specific shipments, refer to www.bricklink.com and search the catalog by name, color, type, et cetera.
Step 2: Domaster's Torso, Arms, & Head (including Dot Matrix Screen)
UPDATE 12/4/2012 - Please see the notations as to where to place the missing two 1x2 plates!
The torso is pretty straight forward. As you'll read about later in the tutorial, nothing is truly set in stone: in other words, you can make your own changes and substitutions if necessary, such as making a different pattern for the screen. This particular instructional guide shows how to perfectly duplicate the quasi-Tetris sprite pattern I attempted to mimic. You're free to use any pattern or tile format you want, provided you at least try to use lime-colored pieces to imitate the original Game Boy color scheme. You can even make a completely solid lime green tiling for the screen, and then use custom stickers or decals to make screenshots (see the decal step later on in the tutorial)! Also, the decorated tiles are optional -- you can use blank ones, or any tile decoration really; I chose these ones to make the robot appear more mechanical!
Step 3: Waist/back Piece
This portion is quick and easy to build; it forms the lower part of Domaster's torso, in addition to the back cover piece that encases his Tetris cartridge. Please note: the gray tile pattern on the back piece isn't definite, and can be substituted with any configuration of light bluish gray tiles, provided they cover up the studs to make the back smooth.
Step 4: Upper Right Thigh
The upper right thigh uses ball and socket joints to connect with the waist and lower leg, and it forms the middle left section of the Game Boy when transformed.
Step 5: Lower Right Leg
This portion forms the second half of Domaster's right leg. The black foot is hinged on an internal tile hook, which rotates inside when transforming.
Step 6: Upper Left Thigh
This module becomes the upper left leg of Domaster in robot mode, and the middle portion of the Game Boy.
Please note: in the primary photo of the completed upper thigh, you'll see a 1x1 transparent clear plate in the top left corner. This piece was accidentally added to the initial render of this section, and was not actually used in the actual model nor guide, so go ahead and disregard it. In fact, the area where you see the plate must be kept empty to ensure clearance for the leg's rotation.
Step 7: Lower Left Leg
The bottom left leg of Domaster, with the noticeable curve on the side -- which mimics the proper shape and speaker of an actual Game Boy.
Step 8: Battery Guns
The battery blasters are one of the few "take-apart-former" portions of the whole model -- meaning you have to remove/add things physically from them to transform, rather than rotating hooks/hinges like Domaster's body. The batteries are pretty much self-explanatory to make, and when in non-weapon mode, can slide into the back of the Game Boy. I used metallic silver 1x1 round plates for the positive connectors, but you can use any grayish color, really. I also went with Duracell, as it's an easy to recognize brand.
Step 9: Tetrawing -- Tetris Cartridge Bird
Tetrawing is the bird-like buddy of Domaster, with an appearance based off Decepticon Laserbeak. His transformation and construction are both pretty simple. Click here for Tetrawing's parts list. As you'll read about later, his color scheme can be swapped with another color -- such as red or blue -- to make a replica Pokémon cartridge instead of Tetris!
Build a yellow Tetrawing that mimics Zapdos, and make his Game Boy label Pokémon Yellow!
Step 10: Assembling Each Module
Once the six major sections are assembled, simply follow the direction of the ball & socket joins to attach each part. In these following images, you'll see yellow arrows which direct the position of the large sections. The rest is basically self-explanatory once they've been built.
Please note: The basic robot structure is moderately sturdy, whilst being weak/rickety in the waist section. The torso is attached to the waist by a mere set of four studs, and thus tends to separate easily when transforming. You'll read about this torso detachment issue in the forthcoming transformation step; also, later on I encourage you all to make any slight engineering/design changes to improve off my base set of plans. For all you know, you could have the solution to securing Domaster's torso to his waist without it coming loose so easily!
Step 11: Transformation Cycles
The transformation from robot to Game Boy is pretty easy, albeit a bit rickety at certain parts (namely the weak connection between the torso and the waist). It's simply a matter of rotating the legs and folding the arms behind the head; Tetrawing transforms in mere seconds.
Please note: it's imperative that you start with the legs first when transforming from robot to Game Boy, as you'll probably end up snapping off the torso if you do it backwards -- for you see, you need plenty of slack to rotate the upper legs, and if the arms are folded back already, they'll more than likely push the legs off. Naturally since this whole thing is made of LEGO, you can easily attach it back together, but if you want an authentic Transformer (and not a take-apart-former) I'd suggest starting with the legs!
Domaster & Batteries:
  1. Fold the black feet inside the lower legs.
  2. Rotate the lower and upper legs, so that the Game Boy buttons are facing the same direction of the screen.
  3. Flick out the side tabs (located on the lower torso, right above the waist). These tabs provide slack for the upper rotation of the legs. When the upper legs are rotated and facing forward, they have to be spread out in a bow-legged position, which if done too hard can force the torso to come loose and separate from the waist. I recommend holding down the torso when rotating the legs, in order to keep the whole unit from falling apart.
  4. Using the hinges on the back piece, fold the back down. Then turn the hinges on the head to move the head/neck to tuck under the shoulders.
  5. The head should be securely folded under the shoulders.
  6. Pop the side tabs back in (the inverse of step 3).
  7. Rotate the arms along the axis of the blue Technic pins.
  8. Turn the ball joint on the upper arm, so that the arms fold behind the chest.
  9. The arms should be folded so the gray plates with the small black areas are exposed (those black pieces are supposed to mimic the appearance of the Game Boy's volume dial and connection port).
  10. Fold the back piece back up to close the unit.
  11. The back of the "legs" have hinges that house the batteries.
Tetrawing:
  1. Rotate the wings to go towards one another.
  2. Fold the green tail downwards slightly, so that it has enough clearance for the under-wing portion. Fold the head and talons along the hook's joints, so that they're resting underneath the wings.
  3. Close the wings to make a square shape.
  4. Fold the green grille tiles so that they're at a 45 degree angle to create the effect of the game cartridge's green microchip showing.
Slide the game cartridge down the back of the Game Boy, and if you folded everything properly, there should be just enough clearance for the game to down about halfway and expose a bit of the Tetris label!
Step 12: Custom Decals & Labels
This part seems a lot harder than it really is, but it becomes pretty easy once you've gotten the hang of it. As this has nothing to do with the engineering nor building structure of the Game Boy, it is not mandatory -- as it is merely a nice little touch to add extra detail and more authenticity to a true Nintendo device!
You'll need:
  • Tweezers -- or in my case, a good set of naturally long fingernails!
  • Transparent waterslide decal paper -- which can be purchased here -- although I bought mine from a random crafts seller on Amazon.com; you can also find this at specialty stores for model cars and trains. It's imperative that you purchase the proper decal type for your printer: You must specifically buy laser decal paper for a laser printer!
  • Scissors
  • A small dish of warm water
  • Magnifying glass (optional)
  • Clear acrylic spray (optional)
  1. After you've downloaded and saved the PDF, do a few "dry runs" by printing out the decal images as one page of regular paper. It's important to print out multiple dry runs rather than immediately printing on the decal sheets -- decal sheets cost money, and your printer might be calibrated to print things slightly smaller than the image on the computer! For example, the vector images on the PDF file are at 100% when you view them in Adobe Illustrator, but when printed out at full size on my office computer, the resulting images were slightly larger than on the screen. I scaled them down to 84% in the printing options, and when printed on a dry run of regular paper, they appeared to be the proper size of actual Game Boy lettering. As I said before, I used a laser printer on my laser decal sheets.
  2. When you've made successful dry runs and determined your printout size, load the decal sheets into your manual tray with the plastic side facing up (as in the direction of where the ink ends up on the paper -- which is traditionally facing upwards). If you don't load in the manual tray, make sure there are no other sheets of paper below the recently inserted decal sheet!
  3. Set your printer in the printing properties option to print in regular/plain paper to avoid printing the sheets with high temperature, as too much heat can screw up the plastic decal by baking it early -- making the labels brittle. The toner shouldn't smear, but if it does, run it through again as light glossy or transparency.
  4. Cut each section of the label from the printout: you don't have to cut exactly along the contour of the shape, as it's printed on clear paper, which won't matter when stuck to a LEGO tile surface. Go ahead and cut each label into a rectangular shape. Cut the A & B buttons into small squares, and make sure to cut the word "BOY" apart from "Nintendo GAME", as they'll be placed on opposite parts of the unit which split apart (see photo).
  5. Using the tweezers (or your freakishly long fingernails like I use), grab each small cutout one piece at a time.
  6. Dip the piece into the dish of warm water (one piece at a time, not multiple cutouts!) and let it stay submerged in the water.
  7. After 10-20 seconds, the warm water will separate the paper backing from the plastic portion of the decal.
  8. Use the tweezers (or fingernails) to gently grab onto a clear part of the label -- avoiding the part with the print -- then carefully stick it on the respective part of the Game Boy (see photo for label placement).
  9. Gently rub your fingers (or a cotton swab) over the recently placed decal to flatten it out and remove air bubbles.
  10. Once the decal dries, it should hold itself in place. You then have the option of putting some acrylic coating on top of it to ensure permanent labeling. I personally didn't do this for my model, as it's truly up to you.
NOTE: the "Dot Matrix with Stereo Sound" label printed dark on my laser printer, and was ultimately hard to see when made into a decal. If you have graphic design experience/software, feel free to adjust the images in the PDF to possibly print out differently for yourself if appears too dark.
You'll need:
  • Good quality sticker paper -- albeit the Tetrawing model I personally built uses glossy cardstock paper decoupaged onto the LEGO tiles, as I wasn't able to obtain sticker paper.
  • An Xacto knife
  1. Like the Game Boy decals, make a few dry runs on regular paper to see if the actual printout fits within the size of the LEGO toy.
  2. When you get the size ready, print out on the sticker sheet and simply cut around the square shape, stick and peel onto Tetrawing.
  3. Feel up the ridges where Tetrawing's wings separate, and use the Xacto to carefully slice through the fault lines -- so that he can transform and his label sticks to the moving parts.
As you'll read about in the final step of this guide, you can substitute the Tetris label with any other Game Boy game label you desire!
Step 13: Nothing Is Set in Stone!
The beauty of LEGO is that most parts come in a wide variety of alternate colors -- which means, as long as you follow the precise engineering instructions on how to construct this model, you can swap the default gray color scheme for anything you want! As long as the gray pieces used in the bulk of the robot are available in abundance of other colors (e.g. blue, yellow, red, green, black), you can easily deviate from my guide and make a color-swap clone! In the attached sample picture below, I used a black and blue color scheme and superimposed a screenshot from Sonic the Hedgehog 2 to create a virtual version of a potential evil Sega clone! This is just one option: you can make a red "fire" Domaster, a green "jungle" commando variation, a white "snow" version -- et cetera, et cetera!
In the mid 1990s, Nintendo released a new line of Game Boys called the "Play it Loud!" series, in which basic monochrome 1st generation Game Boys now had a wide variety of colored outer shells, which included red, black, blue, green, yellow, and transparent clear (see photos) -- which gives you the option of potentially substituting the gray colors of this particular model to mimic a Play it Loud! era unit. If the actual pieces can be found in abundance with the specific color you like, then go ahead and build it that way. Consult Bricklink's color guide and parts catalog to see which pieces are available in existence of your desired color. Gray was easy to work with, as it's a basic staple color that spans over almost every piece made in LEGO's entire parts record. Please note: the dark bluish gray ball & socket joints typically only appear in that color, and to deviate, you might have to alter the parts' construction and improvise. For example, if you want a green 2x2 brick with ball joint, you can combine two 1x2 Technic bricks with axle holes and attach a lone ball piece to mimic the size of a standard ball joint brick (more serious and experienced LEGO builders should have no problem making improvisations to compensate for non-existence of certain pieces of a color family). I do know for a fact, however, that the ball and socket female end also comes in white or dark purple, and you can always try to use Bionicle parts as well for substitutions (and they have more choices, such as pastel shades and metallic).
The screen pattern is truly up to you: I merely made a random pattern of squares to vaguely resemble Tetris pieces, but you're free to use any pattern you'd like, so long as they fit on the 6x6 screen (with preferably a lime green color scheme). You can also make a solid color screen from tiles and then use the same techniques of making custom waterslide decal labels to stick on your own screenshots or sprite patterns, if mosaic LEGO tiles aren't your thing! You can even use any Game Boy label on Tetrawing, and technically he can transform into a game of your choice! For instance, build Tetrawing from predominantly red LEGO pieces, and put on a "Pokemon Red" label to make a Moltres-like firebird!
As far as I know, this is the first transforming Game Boy replica made out of LEGO, and therefore it pleases me to be a pioneer in that sense -- and whilst this is truly a landmark in innovation and custom building, it has its flaws and errors (which basically makes it true to an actual "first generation electronic device!") -- therefore, aside from encouraging you folks to make your own with different color schemes and stickers, I'm also encouraging you all to copy this basic design structure to make your own differently-engineered models, that might be smaller or have more efficient transformation cycles. If you read all of these steps and concluded that you can copy this verbatim -- only with small, more streamlined features, then go ahead and try it out! Who knows: you might successfully build a transforming Game Boy Pocket replica with a pink or purple outer color! Think of this instructional guide as as a basic template or a standard in which all subsequent clones, variations and improvements can be based upon -- just like Wing Gundam being the base model for all other Mobile Suits in the Gundam Wing anime series!
Have fun, don't stress yourself out if you run into engineering issues, and feel free to ask me any questions you might have. Also please point it out if I made any slight errors in parts count, placement or transformation, and I'll be glad to fix those issues.
-Baron von Brunk
