Introduction: Lamp From 2 Glass Bottles
The moment you realize that you like the bottle of a liquor better than what's inside.
In this Instructable, I made a lamp from 2 Glass Bottles.
Almost everything in the lamp was upcycled (apart from the bulb and the bulb socket)
What Was used:
- 2 x Bottles
- Bottle Cutter
- Silicon Carbide Powder or Sandpaper
- Diamond Coated Drill Bits
- Scrap PVC pipe with an end cup
- Nozzle From a Caulk Tube
- Light Bulb Socket
- Cable with the switch
- Perlite (optional)
- Epoxy Glue
- Nut, Bolt and a washer
- Light Bulb
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1:
First I scored a line on 2 bottles.
Then I used candle & Ice technique to split bottle in 2 pieces.
Spin the bottle on top of a candle (so the line is above the flame).
Then cool the line with ice.
Repeat as many times as necessary until the bottle splits in 2 pieces.
Alternatively you can pour hot/cold water on the line or put the bottle in hot water and then in ice bath.
I personally prefer candle and ice, so that's how I did it.
Step 2:
I sanded both bottles with silicon carbide powder.
Put some on a glass sheet and add water.
Use that slurry to sand the bottle.
Alternatively you can use a wet sandpaper.
Step 3:
I used diamond coated drill bits to drill 2 holes in the bottle.
Put the bottle in water and use a CORDLESS drill to make a hole.
I drilled a hole for the cable and a hole for the bolt.
Step 4:
I used a nozzle from a caulk/caulking tube to make a strain relief.
Step 5:
I used a scrap PVC pipe with an end cup.
Cup already had a hole drilled in it, so I made another hole in both pieces to make space for the cable.
Then I slid the pipe onto the cable and attached the light bulb socket.
Step 6:
I glued the pipe to the socket.
Step 7:
I attached the cup to the bottle with a bolt, washer and a nut.
Step 8:
I glued the cable to the nozzle/strain relief
Step 9:
Then I put it all together.
Step 10:
For decorative purpose, I added some perlite.
If you use perlite, make sure it's dry.
If you're not sure, you can dry it in the oven.
Step 11:
The design of this lamp will not let you change the bulb.
Use a bulb that claims to last for many, many years.
Good quality LED suppose to last for 5 years if you burn it 24/7.
Step 12:
Then I glued the other bottle on top.
That's it!
