Introduction: Laser Wood Model Cutting –Eiffel Tower
About: Laser professor
Using the Laser cutter to DIY Eiffel tower
Step 1: Required Items
Setting:
Material:3mm plywood
Laser head:standerd head
Thunder laser used:
Model: Nova 35 laser cutter machine
Laser Tube: 80 watt
Step 2: Setting Parameters:
Processing Mode: cut
Speed: 20mm/s
Max power: 60%
Min power: 70%
After we design the file in CorelDraw, we send the file to laser software directly by clicking the laser plug-in. Then we input the best setting parameters and “Download” the file to the laser cutter.
Step 3: Start Cutting:
Place the wood sheet on the machine working table, move the laser head to the right start position, adjust the focal distance, press “Origin” button to set the starting point, then press “Start” to run the job.
Step 4:
Step 5: Assemble(finished):
After the laser cutter finish working, take out the Eiffel tower pieces and put them aside.
Build the Eiffel tower by yourself, you’ll find there’s a lot of fun to do it.
