Introduction: Leaf Sheep Slug Plush
The Leaf Sheep Slug is my favorite animal. It that can photosynthesize and look cute while doing it.
  • Blue or Purple fabric 1.5 m long, 3 cm wide + a bit for the antennas
  • Green fabric 1.5 m long, 10 cm wide
  • White fabric 20 cm long 15 cm wide + 2 circles 7 cm diameter
  • Black felt or beads for the eyes
  • Thread
Step 1: Sew the Strip of Blue Fabric to the Green Fabric
Pin the fabric with the fluffy sides touching and sew along the outer edge to get one piece with blue on top and green on the bottom
Step 2: Fold and Pin the Strip in Half Lengthwise
Make sure the height of the blue on one side matches the height of the blue on the other side all along the fabric
Step 3: Sketch Out the Spikes
You'll need 5 small spikes and ~18 large ones
Use a pen to mark the fabric. Make sure you test the pen to make sure it doesn't shine through
My picture shows 7 small spikes, but this was too many
Step 4: Sew Along the Lines You Drew
It's ok if it's not perfect, you'll be turning them inside out anyway.
Step 5: Cut Out the Spikes
Step 6: Turn Them Inside-out
Step 7: Stuff the Spikes
You can skip this step if you're using felt
Step 8: Make the Antennas
You make the antennas approximately the same way you made the spikes; by sketching out the shape on the fabric, folding the fabric in half, sewing along the lines, cutting them out, and turning them inside out.
Step 9: Cut Out 3 Rectangles of White Fabric 20 Cm Long 5 Cm Wide
Step 10: Pin the Spikes to the Edge of the White Fabric
Find the middle of your fabric first
You should have either 5 or 6 spikes per layer.
This picture is from after I've done a couple of layers
Step 11: Pin Another Layer of White Fabric on Top
Step 12: Sew This Sandwich Together
Step 13: Pin and Sew a Second Line of Spikes Like the First
Take the piece you have already made and pin the spikes to the edge of the white fabric, put another layer of white fabric on top and sew
Step 14: Pin and Sew a Line of Spikes to the End of the White Fabric to Hold Them in Place
This is going to be the back
Step 15: Pin a Line of Small Spikes to the Other End of the White Fabric
This will be the front
At this point you should have one piece of fabric with a line of small spikes, white fabric, normal spikes, white fabric, normal spikes, white fabric, normal spikes.
Step 16: Pin the Antennas On
I put them between the 1st and 2nd spikes and between the 4th and 5th spikes
Step 17: Sew Along the Edge to Hold the Spikes and Antennas in Place
Step 18: Cut Out 2 Circles of White Fabric
~7 cm diameter
If you're using a less fluffy fabric you might want to add a dart to make it a more natural shape.
Step 19: Sew a Circle to the Front
You'll need to hand sew this
In the end you should have a sort of tube
Step 20: Sew on the Eyes
You can either make eyes out of black felt or use beads
Step 21: Sew It Into a Tube
Sew it inside out
It should be open in the back
Step 22: Turn the Slug Right-side Out
Step 23: Sew the Other Circle on the Back
You won't be able to sew it up all the way, that's ok
Step 24: Stuff the Slug
Step 25: Use a Ladder Stitch to Close Up the Hole
Step 26: Done!
Here's some extra pictures of the finished slug
This is my first self drafted pattern. I'd appreciate any feedback :)
