Introduction: Leather Knuckle Rings
Ingredients:
-.5 mm leather cording, see chart below for length
- 2 tube crimp beads, #4 size
- 3 spacer beads or alphabet beads
Tools:
- Chain nose pliers
- Wire cutters or scissors
Sizing chart
for .5 or 1.0 mm leather only
approximate, size your ring as you work
ring size leather length
6 4 1/2 inches
5 1/2 4 1/4 inches
5 4 inches
4 3 3/4 inches
3 1/2 3 1/2 inches
3 3 1/4 inches
Generally, you will need to adjust the leather by 1/4 inch increments per size.
The leather will stretch, so it's better to make it too tight than too loose.
Click Here for a printable version of this tutorial
Tools:
- Chain nose pliers
Sizing chart
6 4 1/2 inches
5 1/2 4 1/4 inches
5 4 inches
4 3 3/4 inches
3 1/2 3 1/2 inches
3 3 1/4 inches
Step 1: Thread Beads Onto Leather
Fit beads onto the ring in the following order: tube crimp, small spacer bead, large spacer bead, small spacer bead, tube crimp.
Step 2: Adjust Leather Into Ring
Center beads on leather length, make sure ends are even. Loop ends of leather around and fit into the tube crimp from the reverse side.
Step 3: Secure Crimps
Using your chain nose pliers, flatten the tube crimp to hold the leather. Repeat on the other side. If you can only get one end to stay in the tube crimp, it is okay to flatten the first side and then place the leather end in the second side before flattening it.
