Introduction: LEGO SPIKE Prime/Essential LPF2 - QWIIC I2C Connector
This LPF2 connector enables seamless integration of QWIIC devices with LEGO Education SPIKE Prime and SPIKE Essential hubs. Designed for easy and cost-effective assembly, it offers a practical and efficient solution for connecting your devices.
Make sure to have the following parts ordered:
  1. 2 Custom printed circuit boards - use the gerber pcb files in the following github repository to download and order printed circuit boards. - LPF2-QWIIC-Connector/GerberFiles at main · tuftsceeo/LPF2-QWIIC-Connector (github.com)
  2. 4 Resistors - RC0402JR-0710KL YAGEO | Resistors | DigiKey
  3. QWIIC Connector - JST SH 4-pin Right Angle Connector (10-pack) [Qwiic Compatible] : ID 4208 : Adafruit Industries, Unique & fun DIY electronics and kits
  4. 2 channel digital signal booster - PCA9515APWR Texas Instruments | Integrated Circuits (ICs) | DigiKey Marketplace
Step 1: Solder Some Components
Initially, use super glue to bond two PCB layers together, creating a 3.2mm thick PCB that fits perfectly into the LEGO SPIKE hub's LPF2 socket.
Then solder the surface mount components as shown in the photo.
Step 2: Connect Things Together
Connect your connector to a SPIKE hub, and attach a QWIIC device to the connector. See the photos below to make sure that the LFP2 connector is attached with correct orientation.
Step 3: Upload Some Code
Make sure to have Thonny Software downloaded on your computer.
Thonny Software Download Link: Thonny, Python IDE for beginners
The following script will add I2C communication functionality to the Lego brick.
Save The following script as SoftwareI2C.py into the Lego Brick Memory using the Thonny:
from hub import pins as Pin
from hub import uart
import time
import struct
class SoftwareI2C:
    SW_I2C_WAIT_TIME = 40  # Microseconds to wait, adjust based on your needs
    def __init__(self, scl_pin, sda_pin):
        self.en =  Pin.init(0, Pin.EN, Pin.OUT)
        self.en.value(1)
        self.scl = Pin.init(0, scl_pin, Pin.OUT)
        self.sda = Pin.init(0, sda_pin, Pin.OUT)
        self.scl.value(1)
        self.sda.value(1)
    def scl_high(self):
        self.scl.value(1)
    def scl_low(self):
        self.scl.value(0)
    def sda_high(self):
        self.sda.value(1)
    def sda_low(self):
        self.sda.value(0)
    def sda_input(self):
        self.sda = Pin.init(0, Pin.RX, Pin.IN)
    def sda_output(self):
        self.sda = Pin.init(0, Pin.RX, Pin.OUT)
    def delay_us(self, us):
        time.sleep_us(us)
    def start(self):
        self.sda_high()
        self.scl_high()
        self.delay_us(self.SW_I2C_WAIT_TIME)
        self.sda_low()
        self.scl_low()
        self.delay_us(self.SW_I2C_WAIT_TIME * 2)
    def stop(self):
        self.sda_low()
        self.scl_high()
        self.sda_high()
    def check_ack(self):
        self.sda_input()
        self.scl_high()
        ack = not self.sda.value()
        self.scl_low()
        self.sda_output()
        return ack
    def write_byte(self, byte):
        self.scl_low()
        for i in range(8):
            self.sda.value((byte >> (7 - i)) & 1)
            self.scl_high()
            self.scl_low()
        return self.check_ack()
    def read_byte(self, ack=True):
        self.sda_input()
        byte = 0
        for i in range(8):
            self.scl_high()
            byte = (byte << 1) | self.sda.value()
            self.scl_low()
        self.sda_output()
        if ack:
            self.sda_low()
        else:
            self.sda_high()
        self.scl_high()
        self.scl_low()
        self.sda_high()
        return byte
    def scan(self):
        found_devices = []
        for address in range(0x00, 0x78):  # Valid I2C addresses
            self.start()
            #print("add")
            #print(address)
            if self.write_byte(address << 1):  # Shift address for write mode
                #print("found")
                found_devices.append(address)
            self.stop()
        return found_devices
    def writeto(i2c, address, data):
        Write data to an I2C device.
        :param i2c: SoftwareI2C object instance.
        :param address: 7-bit I2C device address.
        :param data: Bytearray or list of data to write.
        i2c.start()
        if i2c.write_byte(address << 1):  # Shift address for write mode and send
            for byte in data:
                if not i2c.write_byte(byte):
                    print("Error: No ACK received after data byte.")
                    break
        else:
            print("Error: No ACK received for address.")
        i2c.stop()
    def readfrom(i2c, address, num_bytes):
        Read data from an I2C device.
        :param num_bytes: Number of bytes to read.
        :return: Data read as a bytearray.
        data = bytearray()
        i2c.start()
        if i2c.write_byte((address << 1) | 1):  # Shift address for read mode and send
            for i in range(num_bytes):
                ack = i < num_bytes - 1  # ACK all but the last byte
                data.append(i2c.read_byte(ack))
        else:
        i2c.stop()
        return data
    def writeto_mem(i2c, device_addr, register_addr, data):
        Write data to a specific register of an I2C device.
        :param i2c: SoftwareI2C object instance, the custom I2C implementation.
        :param device_addr: The 7-bit address of the I2C device.
        :param register_addr: The register address within the I2C device where data will be written.
        :param data: The data to write (as a bytes object or list of bytes).
        i2c.start()  # Start I2C communication
        # Send the device address in write mode
        if not i2c.write_byte(device_addr << 1):
            print("Error: No ACK received for device address.")
            i2c.stop()
            return
        # Send the register address
        if not i2c.write_byte(register_addr):
            print("Error: No ACK received for register address.")
            i2c.stop()
            return
        # Write the data bytes
        for byte in data:
                break
        i2c.stop()  # Stop I2C communication
    def readfrom_mem(i2c, address, register, num_bytes):
        Read data from a specific register of an I2C device.
        :param i2c: The SoftwareI2C object instance.
        :param address: The 7-bit address of the I2C device.
        :param register: The register address within the device from which to read.
        :param num_bytes: The number of bytes to read from the register.
        :return: A bytearray containing the data read from the device.
        # Start the I2C communication and send the device address in write mode
        i2c.start()
        if not i2c.write_byte(address << 1):  # Shift address for write mode
            print("Error: Device not acknowledging write mode.")
            i2c.stop()
            return
        # Write the register address to read from
        if not i2c.write_byte(register):
            print("Error: Device not acknowledging register address.")
            i2c.stop()
            return
        # Repeated start to switch to read mode
        i2c.start()
        if not i2c.write_byte((address << 1) | 1):  # Shift address for read mode
            print("Error: Device not acknowledging read mode.")
            i2c.stop()
            return
        # Read the specified number of bytes
        data = bytearray()
            ack = i < num_bytes - 1  # ACK for all but the last byte
            byte = i2c.read_byte(ack)
            data.append(byte)
        # Stop the I2C communication
        i2c.stop()
        return data
Run the following demo code to scan the connected i2C devices:
import SoftwareI2C
import pins as Pin
i2c = SoftwareI2C(scl_pin=Pin.TX, sda_pin=Pin.RX)
while(1)
    print(i2c.scan())
print("Scanning I2C bus...", i2c.scan())
