Introduction: Lemon Synthesizer
About: Synth Builder Record Digger Social Worker Educator Musician https://theedomites.bandcamp.com/ https://secretsidewalk.bandcamp.com/
This is a touch based lemon synth built off of this macumbista circuit design.
I am working with a friend on a installation piece in Hawaii in July and I wanted to involve a touch based circuit so i can connect it both to plants and his rice bowl installation. Connecting this circuit to the lemon as a conductor is just the tip of the iceberg. I will be adding full solenoid movement and other goods later down the line
Step 1: Finding the Bill of Materials
This is the circuit. Super Easy to breadboard. Not too many components and parts. An easy 20-30 min build for all :)
Step 2: Bread Board Test
I then laid it out on a bread board, powered it up and tested each stage of the circuit.I then connected all the touch points and voila: TOUCH SYNTH
Step 3: Encasement
I then Modge Podged my typical style of collaged anime flicks. I drilled a simple pattern in the plastic cover and laid out a collage anime flicks After the images dried, I mounted the lugs that would be the fixed touch points.
I then screwed the loose leads off the circuit to the lugs. Viola: mounted key touch points
Step 4: More Detail of Encasement
Step 5: Done!
