Introduction: Lifeguard Stand Phone Prop
If you want feel like your at the beach right now, try making this lifeguard stand phone holder! This product will prop up your phone from any angle. You can even just use this product as decoration.
What you will need:
  • Paint
  • Wood/Popsicle sticks
  • Scissors
  • Hot Glue Gun
  • Hot Glue sticks
  • Ruler(Optional)
Step 1: Cutting the Wood/Measurements
These are all of the measurements for the entire project. I used scissors to cut everything, but you can also use popsicle cutters.
Step 2: Painting
Next, you are going to paint everything before you put it all together. You will need white, teal, and dark blue paint. Paint everything white. Then, paint 5 of the 3 inch boards the teal color, you will also paint the 3 inch blocks, one side teal and the other side white. Those same blocks you will then paint a dark blue boarder around the white side.
Step 3: Putting It All Together
Lastly, we need to put this together. After everything is dry from the paint you will have to line up the bottom of the stand and then glue it. Once you have the bottom glued together, you will start on the top. I did the very top of the stand first and worked down. Once you have the top and the bottom completed, you can glue the rest together and you have your lifeguard stand phone prop.
