Introduction: Light-Up Chipboard Robot Toy
About: Hi! I'm Natasha. I'm a Tech-Crafter, Maker, and the Designer of TechnoChic DIY Tech-Craft Kits. Technology should be chic!
Make this chipboard robot light up when you find his secret tickle buttons. (psst..... they are under his armpits. Tee hee!)
In this project, you'll build a simple circuit with Maker Tape, an LED, and a coin cell battery.
  1. 2 sheets of medium weight chipboard
  2. Brass Paper Fasteners
  3. Maker Tape
  4. A Yellow Straw Hat LED
  5. CR1616 Coin Cell Battery
  6. Clear Tape
  7. White Glue
  8. Gold and Silver Paint
  9. Black Sharpie Marker
I hope you will enjoy this tutorial!
If you want to see more of my work, you can follow me here on Instructables and on Instagram and YouTube - Please Subscribe! You can also buy tech-craft kits designed by me at TechnoChic.net.
I've also included links to all of the supplies. As an Amazon Associate, I earn a small commission on purchases made through the links above, and that helps me make more tutorials like this. :)
Step 1: Draw the Robot
On the chipboard, draw simple shapes with a black marker to make a robot. Most robot shapes are simple squares, triangles, and circles, so experiment and make your robot unique!
Step 2: Cut Out the Shapes
Cut out all of the shapes with a craft knife. Go over the edges with the black marker to make them look finished.
Step 3: Attach the Arms With Paper Fasteners
Use a hole punch or sharp point to poke a hole in the arms and body, and connect the two with paper fasteners.
Step 4: Glue the Parts Together
Glue the remaining parts together with tacky glue. Let it dry.
Step 5: Paint the Accents
Paint the accents with gold and silver paint.
Step 6: Place the LED
Poke two holes in the center of the body and place the LED through.
Step 7: More Paint
Paint the area around the LED to reflect its shine. Let it dry.
Step 8: Lay Out the Circuit With Maker Tape
Create the circuit on the back as shown:
  1. Put regular tape over the paper fasteners to prevent them from shorting out the circuit.
  2. Add maker tape to the negative (shorter) leg of the LED.
  3. Place the battery on top, negative side down, then place maker tape over it.
  4. Continue laying the maker tape as shown.
Step 9: Create the Switches
Tape paper flaps (with a piece of Maker Tape inside and the edges folded over) under each armpit to close the switch.
Step 10: Light It Up!
When both armpits are tickled, the robot’s LED lights up!
I hope you enjoyed this tutorial! If you want to see more of my work, you can follow me here on Instructables and on Instagram and YouTube - Please Subscribe!
You can also buy tech-craft kits and templates designed by me at TechnoChic.net.
