Introduction: Lighter
You will need: A lighter Flint Lighter fluid Lighter wool
Step 1: Dissemble
Take bottom screws out and take wool out of the bottom hole. If you are using a zippo open the lid, there should be a hinge on a spring. Flip up the hinge and you can pull the middle away from the casing. Remove the screw at the bottom, pull out square wool at the bottom and remove the rest of the wool
Step 2: Flint
Put one flint down the small hole
Step 3: Wick
Stuff the wick up through the hole in the top.
Step 4: Wool
Add the put the wool in small bits into the lighter. Make shure you move the wick from side to side then you do this so it dosnt get tangled.
Step 5: Fluid
Add the lighter fluid and put back together
