Introduction: Lighter Hack!!
A easy, small, and simple way to make a AWESOME FLAME THROWER!
The priceless faces that your friends make when they see this thing shoots out 4ft!
Step 1: Parts
-butane
-light with adjustable gas
-pliers
-a few minutes of time
-pliers
Step 2: Taking Apart
-take off the flame guard
-remove the spark wheel
-flint and a spring will come out
YOU DONT NEED THESE ANYMORE!
-remove the gas button
KEEP IT!
-also remove the gas adjuster. Throw it away!
KEEP IT!
Step 3: Perpetration for It to Be Filled
-unscrew the gas adjuster (it's the green thing that gives the gas more am less flow)
-pull it out be care full there are two parts after you pull that out!
-the is a little circle thing and the white thing inside the light
THROW THE ROUND THING AWAY!
KEEP THE WICK THING!!
Step 4: Putting Back Together
-put the wick back is
-screw the green thing in! (THIGHT AND ALL THE WAY!!)
-put the gas button back in
Step 5: Re Filling
-take the tip and push it down as you push the gas button and you should see it fill up.
Step 6: Just for Fun
Make a pull string for it.
-cut a wire
-make a loop
-feed a key ring onto it!
-cut a wire
-make a loop
Step 7: FIRE
Put a lighter in front of it a FIRE!
