Introduction: Lighting 60's Pin UP
About: I enjoy using my hands to create something and then share it!!!!!
Everybody knows 60's pinup, they are a symbol about beauty and elegance!!
So I decided to create my own !! :)
Step 1: Choose Your Model
Here is the base of my pinup!!
For your own, you need to chose one who has a nice shape to be well visible when you will just keep a global and simplified shape!!
Step 2: What Do You Need!
For this instructable you will need :
-3 meters of El wire (choose youf color for your pinup, here it is orange something quite neutral)
-1 plexiglass sheet of 3 mm thickness
-pinup shape
Step 3: Cut the Plexiglass Shape
You need to cut carefully and slowly your pinup with respect ;)
And little by little you can design better shapes!!!!
Step 4: Stick El Wire
To stick el wire you need to use a hot glue gun and press the el wire on plexiglass stroke with your finger!!!!
But take care it's HOT like HOT GLUE!!!! ;)
Step 5: Plug El Wire and It Glows !!!!
Here we go it glows with just one 3volts alimentation but you can add one 1.5 volts battery to make your el wire lighter.
For 3 meters EL wire can be powered by 4.5 volts.
So now let's try it !!!! It is easy :)
