Introduction: LuckHeart Island
Today, I will show you how to make this amazing Floating Island!
All you need to make this is a trusty computer and a Tinkercad account!
Step 1: Step 1: Create Triangle
You need to create a triangle and scale the object up a bit
Step 2: Step 2: Make a Cube
Make a cube and scale it up just little bit
Step 3: Step 3: Forming Island Pt1
Put the cube inside of the Triangle but make it stick out a little bit
Step 4: Step 4 Forming Island Pt2
Duplicate that square a bunch of times and do the same thing
Step 5: Step 5: Add Grass
Add a cylinder, flatten it, make it the same size as the island base and then change the color to green
Step 6: Step 6: Add Some Extra Detail to the Grass
add some extra detail to the grass to make it look N I C E
Step 7: Step 7: Add Mountain
Add a huge triangle to the center of the island
Step 8: Step 8: Add Detail
Add extra detail to the mountain
Step 9: Step 9: Add a Rim to the Island
Add a rim to the island and color it dark green
Step 10: Step 10: Add a River Hole
Create a hole object that outline the inside of the island then group it to the island so that it creates a hole for the water.
Step 11: Step 11: Add Water
Add a light blue cylinder that will fill the hole that you made in the island
Step 12: Step 12: Make the Bridge
Create a bridge using the round roof element and creating a hole at the bottom of it
Step 13: Step 13: Applying Bridge
Add the bridge to the rest of the model and add extra details on it if you want to.
Step 14: Step 14: Make a Cave
Create a cave in the mountains by making a square hole at the base of the mountain and then filling it with a light brown interior.
Step 15: Step 15: Add Extra Features
Add an extra feature like a house. It doesn't have to be specifically a house but use your imagination a little bit. I made a little house for mine =)
Step 16: Step 16: Mountain Detail
Add a little bit of extra detail to the mountain such as an extra green gradient
Step 17: Step 17: Make Extra Islands
Create small extra islands by following the same routine as at the beginning and then make it smaller.
Step 18: Step 18: Make More Tiny Islands
Duplicate the tiny islands and put them in random places to orbit around the main island
Step 19: Step 19: Creating Trees Pt1
Make a small cylinder and make it brown
Step 20: Creating Trees Pt2
Make different colored squares around the top of the tree and duplicate them to create a bushy leaf effect
Step 21: Step 21: Implementing the Trees
Duplicate the trees and put them around the island
Step 22: Step: Marvel at Your Masterpiece
Just look at it =D
Step 23: Step 23: Export It
Export the model as an obj file and import it into something like unity to look at it!
=D
