LunchTop: a Raspberry Pi Lunch Box Laptop
15K10923
Intro: LunchTop: a Raspberry Pi Lunch Box Laptop
This is a fun and fairly easy project to build a portable Raspberry Pi computer that fits right into a standard lunch box. This is a good project to start with since it doesn't require much technical knowledge. All you have to do is purchase the parts necessary to build the LunchTop, plug everything in and secure it to the inside of the lunch box.
I have listed all the parts used in this project with cost and links to purchase the items, but you can feel free to look around for alternative parts.
STEP 1: Parts List
Raspberry Pi 3 Model B Basic Starter Kit $49.99
https://www.amazon.com/gp/product/B01D92SSX6
32GB SD Card $10.59
https://www.amazon.com/gp/product/B010Q57T02
HDMI 7" Touch Screen LCD $72.00
https://www.amazon.com/gp/product/B0153R2A9I
Touch Screen LCD Case $12.07
https://www.amazon.com/gp/product/B01GQFUWIC
Wireless Bluetooth Keyboard & Mouse $15.07
https://www.amazon.com/gp/product/B01KTDYQ5C
ROMOSS 10,000 mAh USB Battery $12.99
https://www.walmart.com/ip/49544020
1 foot Micro USB Cable $3.99
https://www.amazon.com/StarTech-1ft-Micro-USB-Cab...
3 foot Micro USB Cable $6.84
Custom Lunchbox $14.96
https://www.amazon.com/gp/product/B01AX14I7G
Velcro Squares $2.93
http://www.homedepot.com/p/VELCRO-brand-7-8-in-St...
Total cost $201.43
STEP 2: Modify the LCD Case
I needed to modify the Touchscreen LCD case because the one micro USB cable that attaches to the monitor board needs to come out of the side of the enclosure so that it can plug into the Raspberry Pi. To do this you will need a drill and drill bits. Start with the smallest drill bit and work your way up to 3/8" bit. This will be big enough so the micro USB cable can be feed through the enclosure.
STEP 3: Assembly of the LunchTop
The first step to assembling the LunchTop is to completely assemble the Raspberry Pi, then attach it to the LCD screen and finally secure it with the LCD cover.
Once that is complete your next step is to attach all the parts to the lunchbox and hook up all the cables. I used Velcro strips to secure the battery, Raspberry Pi, game controller and keyboard. This allows me to easily disconnect everything so I can use the Raspberry Pi on other projects (e.g. breadboard and sensor kits).
STEP 4: My Raspberry Pi LunchTop
Here is what the completed project looks like. Now go and start building your LunchTop computer and share your results in the comments section.
15 Comments
would it be possible to use this instead of what you had in your project?
Yes this is a touch screen, that is why it is a little more expensive. You can build the same LunchTop using a regular display.
Csn this be made touch screen?
What additional details are you inquiring about?
great job. I would like to see more details on the build though. How long does the battery last?
Depends on how much you use it daily but I usually get 2-3 days out of it between charges.
how long does the battery last?
nice job and very good instructable
Great job man!! looks really cool!
Cool project! Kudos to your helper, start 'em young.
