Introduction: MIDI Controller With Keyboards
Today we're building the 400 key MIDI controller using an Arduino and computer keyboards!
For the budget conscious music producers out there, this project is a great way to build an inexpensive control board for your digital audio workstation.
Or if you're just a musician with an odd taste for instruments, this geeky looking device will surely give you some strange looks.
Step 1: Watch the Video!
Check out this quick video to see how this mega MIDI device translates to an instrument and for a run-through of all the steps below from start to finish.
Step 2: What We'll Need...
We're going to build a box that translates signals from multiple keyboards into standard MIDI out signals.
To do so, we'll need:
- An Arduino (I'll be using the UNO, but any other variants will work fine)
- 2 PS/2 ports (as many as you'd like, as long as there's enough digital pins on the Arduino for it)
- MIDI female port
- Cardboard
- A 220Ω resistor
- Perboard
- Wires
Keyboards!
Where to buy
- PS2 jacks: http://amzn.to/2dPQ3lj
- Arduino UNO: http://amzn.to/2dq41Mv
- MIDI port: http://amzn.to/2dt5Tmp
- Resistor pack: http://amzn.to/2d8uQaw
- Perfboard: http://amzn.to/2cQcN7q
- Keyboards: http://amzn.to/2dc95Bl
Soldering gear:
- Weller WES51 Analog Soldering Station: http://amzn.to/2dq7Q4m
- MG Chemicals Silver Solder: http://amzn.to/2dHj0nq
- Helping hand: http://amzn.to/2dc553O
Testing gear:
- Multimeter: http://amzn.to/2dc54N6
- Breadboard & Jumpers: http://amzn.to/2dHknm2
Step 3: Prepare the PS/2 Ports
Push a piece of perfboard through the bottom pins of the PS/2 ports to make soldering easier.
Clamp the PS/2 ports in place and solder wires to the four pins of each of the PS/2 port that we need to access (they are the Vcc, Ground, Clock, and Data pins - see diagram).
Hot glue the PS/2 ports together.
Step 4: Prepare the MIDI Port
Push a piece of perfboard through the bottom pins of the MIDI port to make soldering easier.
Add a 220Ω resistor in series to the Vcc pin (see diagram).
Solder wires to the three pins we need to access (they are the Vcc, Ground and Serial pins - see diagram).
Step 5: Wire Up the Arduino
Wire the PS/2 and MIDI ports to the Arduino as follows:
For the PS/2 ports:
- Vcc pins goes to 5V
- Ground to GND
- Clock and Data pins goes to digital pins 4 to 11
For the MIDI port:
- Vcc pin goes to the 220Ω resistor, then to 5V
- Ground to GND
- Serial to TX
Step 6: Upload the Arduino Program
I've made the source code to this project open-source, so simply head over my GitHub to download the Arduino sketch:
https://github.com/evankale/ArduinoMidiPS2
Plug in the Arduino to the PC, open up the sketch in Arduino IDE, and upload the program to the Arduino.
Step 7: Make a Box
Cut out a cardboard box template that fits all the components.
I decided to expose the MIDI and PS/2 ports in the front of the box while the Arduino USB port through the back so that it can be USB powered or reprogrammed easily.
Hot glue the components into place.
Step 8: Close Up the Box
Close up the box with some PVA glue, and admire your work of art.
Step 9: Find Keyboards
Just for fun, I decided to attach three old keyboards together with some wood pieces and screws.
Attach two strap buttons, put on a strap, and we have a very unique "keytar" to go with our MIDI box.
Step 10: Plug It in and Give It a Test
Plug in as many keyboards as you'd like and give it a test!
Watch the video to see the MIDI controller in action.
That's all I have for you today!
If you liked this Instructable, then perhaps you'll like some of my other projects!
You can check them out over at my YouTube channel.
New projects every Thursday! See you next week!
