Introduction: Turn an Old Speaker Into an MP3 Player in 10 Minutes
In this instructable, I 'll show you how I converted my ordinary speakers into an MP3 speaker.
The MP3 player gets its power from the speaker power source.
Here is my Channel on Youtube:
AeroArduino
Step 1: Stuff You Need
You 'll need :
7805 --- 5 V Voltage Regulator from Amazon or eBay Here
Speakers
USB Female Connector - - I used an old USB Male/Female Cable and cut it from the Female side . get it from Amazon or eBay Here
MP3 Player
Soldering iron get it from Amazon or eBay Here
Wires
Tape
Step 2: Start Working
Open the Speaker from the power supply side.
Connect wires to the voltage regulator.
Insulate the regulator and wires with tape.
Find the 9 Volts DC coming from the rectifier circuit after the transformer , diodes and capacitors. This should be the input of the regulator.
Find the ground of the circuit. This will be connected to the ground terminal of the regulator and the negative terminal of the USB connector.
Weld the wire connected to the input terminal of the regulator with the 9 Volts point you found earlier.
Weld the wire connected to the regulator Ground to the Ground point you found earlier.
Step 3: Mount the USB Connector
Step 4: Close the Speaker and Use the MP3
Now , close the speaker , put some MP3 files on the MP3 player and start using your new device.
Thank you for reading my instructable.
You can also find my book Learn By Making on Amazon website.
If you like this instructable you can support us by many ways:
1. Leave comments stating your point of view about this article.
2. Buy our book on Amazon Learn By Making.
Thank you for visiting our instructable.
Here are some of my latest books on Amazon.
