Introduction: Make a Bright Led Lamp
Hello fellow makers! Today I will be showing you how to make a LED battery lamp
Step 1: Materials
9 volt battery
Any resistor that goes with your led
A led
A tiny perfboard
Locking momentarily switch
9 volt battery clip
Tools:
Solder iron
Hot glue gun
Ok let's go!
A led
A tiny perfboard
9 volt battery clip
Tools:
Solder iron
Hot glue gun
Ok let's go!
Step 2: Solder the Battery Clip
First solder the battery clip to the end and corner of the perfboard.
Step 3: Solder the Switch
Now place the switch in the middle. While soldering connect it to the 2 wires coming from the battery leads and solder it in palce
Step 4: The Resistor
Now place the resistor. Since this perfboard is small you have to place it up right. Bend one lead towards the switch's contacts and the other one away from it
Step 5: The LED
Now place the led at the very end of the board. Bend the negative lead towards the contact of the negative battery clip. Then bend the positive over the free resistor leg. Solder all of it together. Clip the excess lead off.
Step 6: Glue the Battery Clip
Now put some hot glue on the back of the board and attach the battery clip to the back.
Step 7: Done!
Now attack the clip to the battery. It should now light up. If not you might of got the led polarity wrong. Now you can use this to light up dark closets.
