Introduction: Pretty Up a Lamp Shade With Cutouts.
This kind of gives a light show effect. Sorta, I mean, it's not exactly a Kanye style light show, but it does throw pretty patterns onto the wall and ceiling and it's dead easy to make.
I think I've covered the basics here, but if you get stuck (or you're looking for some other ideas on Dirt Cheap Decorating) go here
Step 1: Gather Your Stuff
I used:
a Grundtal lamp base from Ikea
a Skimra lamp shade from Ikea
craft paper
scissor
a craft knife
tape
pencil
craft paper
scissor
a craft knife
tape
pencil
Step 2: Figure Out the Area You Have to Work With
Draw 'round your lamp shade, to figure out it's surface area.
Step 3: Plot Out Then Cut Out Your Design
Bear in mind that you won't be cutting out the whole outline of your design, just peeling up the edges.
Step 4: Pinch Out Your Edges
Pop the template over the lamp shade and secure it with a bit of tape. Then peel and pinch out the edges of your design, this will let you see how it's going to look.
Step 5: Plot Out Then Cut Out Your Design... Again
This time you'll be marking out your design onto the actual lampshade, using a pencil and your pre-cut outlines as a guide. Once that's done, carefully cut out your design using a craft knife.
Step 6: Pinch Out Yor Edges... Again
This is slightly harder than it is with the paper template. Clean hands and patience come in useful here.
Also try folding your edges back a few degrees at a time rather than jamming them back all the way in one go.
Step 7: Your Lamp Is Complete!
Once you've pinched out all your egdes your lamp is done!
It looks ok in daylight, but best when it's lit up in a dark room.
