Make an Easy Weekend Patchwork Quilt Topper
Intro: Make an Easy Weekend Patchwork Quilt Topper
The size of the squares can be adjusted to make it fit any size bed, crib or daybed by simply measuring the mattress top, dividing by 6 and adding 1/2 inch per square for seam allowances.
STEP 1: Materials and Prep
- 2 yards of each, 3 plain, 3 pattern fabrics cut into 6 inch Squares for Full/Queen Size Quilt.
- Pattern, (below)
- Rotary Mat and Cutter (optional)
- Ruler
- Scissors or Pinking Shears
- Sewing Machine or Serger
- Iron
- Ironing Board
Prepare:
When selecting your fabrics try to stick to the same weight and type of material. I found after cutting my squares that the pink butterfly fabric was too heavy or bulky with the other fabrics and had to make a trip back to the fabric store to choose another material. Also make sure your fabrics are machine washable to avoid dry cleaning bills on such a large item.
Wash, dry and iron all fabrics to eliminate the possibility of shrinkage after your quilt is finished.
Cut 33 squares of fabrics 1 through 5 and 34 squares of fabric 6.
Once your quilt squares are cut lay them side by side plain, pattern, plain (or vice versa) to determine how you want your pattern to work out. The last color will be the most prominent on the quilt. Once you have decided how you want your pieces to lay in the design assign each fabric a number from 1 to 6 and set them in order on the table so you only have to move down the line when you pick them up from the pile as they are added to your quilt.
*Note: If you have access to a serger and a rotary cutter and mat I highly recommend using them as it will save 2/3 of the time you will spend cutting squares with scissors, trimming and pressing seams open during the assembly of your quilt and will provide more uniform squares.
If you must cut your squares by hand pinking shears are your best choice to prevent raveling because of heavy handling and will reduce raised or lumpy areas under your seams.
STEP 2: Begin First Rows
As you finish each strip match it lengthwise to the previous sewn strip. (If you are using a regular sewing machine press seams open first) Pin on seam lines with the seams facing the center of the quilt row.
6 1 2 3 4 5 6 5 4 3 2 1 6 1 2 3 4 5 6 1 6 5 4 3 2 1 2 3 4 5 6 1 2 1 6 5 432 3 4 5 6 1 232 1 6 5 4 3 4 5 6 1 2 3 4 3 2 1 6 5 4 5 6 1 2 3 4 5 4 3 2 1 6 5 6 1 234 5 6 5 4 3 2 1 6 5 6 1 2 3 4 5 4 3 2 1 6 5 4 5 6 1 234 3 2 1 6 5 4 3 4 5 6 1 2 3 2 1 6 5 4 3 2 3 4 5 6 1 2 1 6 5 4 3 2 1 2 3 4 5 6 1 6 5 4 3 2 1 6 1 2 3 4 5 6 5 4 3 2 1 6
STEP 3:
STEP 4: Half Way Through
I recommend sewing strips together until you reach the middle row, which will be a repeat of the very first row you made, set the piece aside and continue making strips, following the pattern for the lower half of the quilt as you did for the upper half.
Once the bottom half is complete pin it to the upper half and stitch both halves together. This way you only have to deal with the full bulk of the quilt once.
STEP 5: Finishing
You can add borders now if you want more overhang or extra for tucking pillows under - if you choose not to add a border you are ready to add your batting and backing and finish the quilt.
Note: It is generally less expensive to purchase a flat sheet or sheet set for you backing piece, if you purchase a sheet set then you also have pillow cases and a bottom sheet to match.
63 Comments
maryknowsbest2 5 years ago
MotherRoche 3 years ago
Regards
Rochelle
Trash-Treasure 3 years ago
linzelou 5 years ago
MikeB706 6 years ago
Shannon towe 6 years ago
luvdfins 7 years ago
I have made several quilts using this pattern. It's called "Trip Around the World". It's a very easy pattern and I've received many compliments on the quilts I've made. If you're new or just want a quick quilt to make this is the one for you. I've been looking for a similar easy pattern but so far haven't found any. Does anyone have any suggestions?
LoriD69 7 years ago
where do i get this pattern
josie1957 8 years ago
Hello, I am a beginner too and have made 3 quilts with a straight stitch sewing machine, I have used this old machine for almost 20yrs now. My friend has asked me to make her one in red and grey, so I'm using two different shades of grey. What colour binding would go nicely with this? Any suggestions? Too me, this pattern with the red and greys looks like a checker board. Lol! I hope the upload went through ok.
TiffanyL41 8 years ago
msmarvrhn 8 years ago
I do not pre wash my fabric before cutting and completing the quilt. If you are afraid of colors running you can purchase a product by shout that catches the colors before they run into your other quit blocks.
This quilt pattern looks very easy and surging and sewing machine instructions are available. I am into large blocks and with pattern is very easy to increase block size.
LeeB61 9 years ago
Oliviaschaefer22 9 years ago
how many yards for the backing and batting
fuffuff 9 years ago
I want to make my son a quilt for him to use while he is at college. This looks like a simple design I can make without too much fuss. Earlier today, I ordered University of Cincinnati fabric for his quilt, not having any idea of what pattern I would use. This may be the winner!
Soh HuiC 9 years ago
If I were to make it for a single bed, how do i calculate the number of squares to arrive at a pattern? Thank you.
ChloeH5 9 years ago
Thank you for this easy and simple design I'll try to make it for my caravan
kevin1790 11 years ago
Sus93 12 years ago
