Introduction: Make Coca Cola Soda Fountain Dispenser Machine at Your Home Fridge !
About: Ideas Into Reality !
Make a Coca Cola Soda Machine for your fridge or refrigerator. You can build this Coke soda machine easily homemade & very cheap. This DIY Soda Fountain Machine let you grab drinks in coca cola without spilling drink all over. You can install this in your fridge to enjoy chilled water coke coca cola sprite fanta almost any carbonated drink. You can do this to make your fridge with water dispenser. So Lets Make a coca cola fountain machine for your home fridge.
You can watch my fridge soda dispenser here !
https://youtu.be/5fPORlRqL2A
★☆★ For more awesome content ★☆★
https://www.youtube.com/kedarnimbalkard
★☆★ Find me here ★☆★
https://www.facebook.com/KedardNimbalkar https://twitter.com/kedardn
References -
https://en.wikipedia.org/wiki/Soda_fountain https://en.wikipedia.org/wiki/Vending_machine https://en.wikipedia.org/wiki/Soda_fountain https://en.wikipedia.org/wiki/Wine_dispenser
Step 1: Things You Will Need !
1) 6V DC Air Pump X 3 http://geni.us/uvQF
2) Push Buttons X 3 http://geni.us/ta3mMO2
3) Soda Bottle Supply (Coca Cola , Sprite , Fanta or any of your choice) http://geni.us/XBuAO
4) 9v Battery http://geni.us/6dipfa
5) Plastic Tube (Food Grade) http://geni.us/TquiDw
6)1 sqmm Electrical wires
7) Drill or Dremel Tool
8) Plastic Box
Step 2: Simple Electrical Wiring
1. Mini 6v air pump is really easy to use ,when you connect a 9v battery it will pump out lot of air ,if it doesn't then flip the battery polarities.
2. Now connect red wires to the positively marked red dot terminal of each motor .
3. connect a push button to each motor's negative terminal
4. Connect the remaining terminal of three switches to negative of the battery .
Step 3: Control Panel Box Assembly !
1. when electrical connections are finished take a plastic box and drill holes for inlet , outlet , switches and dispenser outlet
2. to make look the panel box even i used white paper from inside
3. then install switches ,motors, and all components inside
4. your finished product will look something like this >
Step 4: Modification to Soda Bottle Cap !
1. Now You need to modify the bottle cap so drill two holes for outlet and motor pressure . your soda will not go through motor instead motor will build air pressure inside soda bottle and soda will exit from other tube .
2. Now cut two tubes according to your bottle size , but the outlet tube should reach bottom of the bottle ,you can keep other tube short .
3. Now Use hot glue to seal around the holes properly
4. You're good to go !!!
Step 5: Test 1... Success !!!
Now Let's do a test run
1. connect one tube of bottle to a motor
2. and press button ,Whola ! you got your drink Dispensed !!!
Step 6: Installing Inside the Fridge! - Enjoy
Okay Guy's Now you can Install This system into your fridge and always enjoy cool drinks at a push of button !
if you missed any step watch full video here https://youtu.be/5fPORlRqL2A
