Introduction: Make Your Own T-Shirt Art
About: Artist. Seamstress. Photographer.
I LOVE this DIY Project!
You can create your own design from
magazine clippings, photographs, or anything else you can think of using!
Step 1: What You Will Need
What You Will Need:
Scanner/Printer
Iron-on Transfers (Found at any Office Supply Store)
Sheet of Printer Paper
Computer
T-Shirt
Iron
Hard Surface to iron on
Mod Podge or Elmers Glue
Magazines, Photographs, etc.
Scissors
Optional:
If you do not have a scanner you can do this project with a photo/design from the internet. If you choose to do this skip down to the step where you print your design.
NOTE:
Light Colored Shirts need Iron-on transfers for Light Fabric
Dark Colored Shirts need Iron-on transfers for Dark Fabric
*Iron-on Transfers for Dark colored shirts are more expensive*
Step 2: Lets Begin
If you are making your own t-shirt art
Start Here:
Make a collage on a piece of printer paper.
You can use magazines, photographs, or anything else you would like!
Use Mod Podge or Elmers Glue to secure your creation to the paper.
Do not over saturate the paper!
Use just enough adhesive to keep the
picture attached while you scan it to your computer.
Step 3: Print Your Transfer
Hook your computer up to your printer.
Lay your collage face down and scan it to your computer.
NOTE: You will need to reverse your image so the picture/words face the right way when you iron on your collage.
HOW TO REVERSE YOUR IMAGE:
Open Paint. Drag and Drop your Photo into Paint.
Click Control+R and choose Flip Horizontally
Save Image.
It should look backwards compared to your original image.
When you are ready print your image on the transfer paper.
Lay your Transfer paper face down and print your image.
(Please read the directions that came in the Iron-on Transfers packet since each printer is different)
Step 4: Prep Your T-shirt and Cut Out Your Transfer
Iron your shirt so there are no wrinkles on it.
Cut your design out. Leave little or no space around the design.
If you leave a white border around your design it will show up on your shirt.
If you do not want a white border cut close to your design when cutting it out.
Step 5: Iron on Your Transfer
Lay your design face down.
Make sure it is centered or exactly where you want it to be when you are finished.
Iron on your design.
Set Iron to Cotton Setting
PRESS HARD AND EVEN
Make sure you iron the edges and middle really well!
(Again, check the iron-on transfer instructions to see how long you should iron your design)
When you are finished, allow the transfer to cool (2-3mins)
Then, slowly peel the transfer starting from the bottom.
Allow design to cool.
Step 6: YOURE FINISHED!!
This is another project that you can get as creative as you want with!
Come Back Soon!
To see more DIY Projects visit my blog at: korrinewojcik.blogspot.com
