Make a Bench Vise for Woodworking
Intro: Make a Bench Vise for Woodworking
This bench vise – sometimes called Moxon’s Vise – is inexpensive to make, portable, and works very well for holding your work pieces while sawing, chiseling, or planing. There are many designs for this vise available on the Internet; I’ll show you my version. Feel free to adjust the dimensions to suit your own needs.
STEP 1: What You Need
Supplies:
- About 16 linear feet of one by six hardwood (actual measurements ¾” x 5½”). I used birch, which looks nice and is hard/strong enough for the vise.
- Two hex bolts ½” by 8" to 10” long and two ½” flange nuts
- Wood glue, epoxy
Tools:
Table Saw, Drill Press, ½” , ¾”, and 1” Forstner Bits, Sander, Clamps
STEP 2: Front Jaw
Cut two 32” long pieces from the one by six board. Glue the two faces of the 32” boards together to make the front jaw of the vise. The jaw will be 32” by 5½” by 1½” thick.
STEP 3: Rear Jaw
The rear jaw is L-shaped. The short ‘lip’ is used to clamp the rear jaw to your workbench. Edge-glue the 30” by 2½” board to the 36” by 5½” board as shown in the drawing, lining up the centers. I used biscuits in this joint, but you don’t need to do that if you don’t have a biscuit joiner. After the glue dries, glue on the 36” by 4¾” board and the other 30” board to complete the rear jaw.
STEP 4: Drill Holes for the Hex Bolts
Drill two ½” holes through the front jaw 3” from the short edge and 2 ¼” from the top edge. Use a drill press, as the holes need to be straight through.
Line up the front and rear jaw along the top edge (match up the centers), then use the ½” Forstner bit in the front jaw holes to mark the location for the holes in the rear jaw. Be as precise as you can to avoid any binding of the screws in the finished vise. Then drill the holes through the rear jaw on your drill press.
On the backside of the rear jaw, drill shallow 1” diameter recesses around the two holes to receive the flange nuts.
STEP 5: Make Handles
You could stop right here and use ½” hex bolts and washers to complete the vise and open/close it with a wrench.
I decided to make wooden handles for the hex bolt as shown in the picture. Glue together three boards with dimensions of ¾” by 2¼” by 11”. You’ll end up with a wooden stick 2¼” square. Trim this stick into an octagon. A very easy way to do this is shown in this Instructable:
https://www.instructables.com/id/Easiest-way-to-make-octagons-for-wood-turning-NO-/
Cut the octagonal stick into two 5½” pieces making sure the cuts are square. Then drill ¾” holes down the center axis 2” to 3” deep; whatever your drill press can handle. Be sure the holes are straight down the middle.
Insert the hex bolt head first into this hole, make sure the bolt is straight with the octagonal handle, fill the hole with epoxy around the bolt, and let cure. Your handles are done!
STEP 6: Use Your Bench Vise
I did not use any finish on the bench vise or handles. I plan to sand it down if it needs cleaning.
Use some beeswax on the bolt threads and in the thru-holes to make turning the hand screws easier.
To use the bench vise clamp the rear jaw to the edge of your workbench, insert the work piece, and tighten the jaws.
22 Comments
PhuketAussie1973 7 years ago
Very nice tutorial, I like the Moxon vise, and this is a nice way to make one, though I'm considering building this into the side of my bench as a fixed woodworking vise, instead of buying the common kind.
DanielM249 8 years ago
rschoenm 8 years ago
Yonatan24 9 years ago
Hi, I've added your project to the "Make Your Own Bench-Vise!" Collection
This is the link If you are interested:
https://www.instructables.com/id/Make-Your-Own-Benc...
rollsurf 9 years ago
rschoenm 9 years ago
I got the 8" hex bolt at either Lowes or Home Depot. It does not need to be threaded all the way. You epoxy about 2" into the wooden handle, another 1-1/2" is covered by the front jaw of the vise.
Or you could buy threaded rod and cut it to any length you need.
buck2217 9 years ago
Great Idea well done
BeachsideHank 9 years ago
One might find individual 1/2- 13 T-nuts at the hardware store, in those drawers of misc. parts usually in the back end, up against a wall in a dimly lit area, if anything like mine. :-)
T-Nuts would be a good choice if you can't find flange nuts. Or use a regular hex nut and cut a hexagonal hole to mount it in the rear jaw.
bethany.theilman 9 years ago
Fastenal has nice 1/2 - 13 flange nuts -a bag of 10 stainless steel ones was 14 bucks. I made one of these and promptly gave it to my friend who had no vise in her shop and was hosting a dovetail class. Off to my lumberyard again! Maybe I will spring for maple this time.
JamesC32 9 years ago
Great project but it struck me? Why not adapt the jaws of the vice to fit the "Workmate" it is sitting on? Two tools in one.
That’s a good idea, a very good option; and it wouldn’t be difficult to do. I use the bench vise on two different workbenches as well as on the ‘Workmate’; so I like the portability of the design.
andrea biffi 9 years ago
so useful, I'll make one for sure!
Seelos 9 years ago
Very nice! Your CAD drawings are clean. What program are you using to make the drawings?
Thanks. I am using the free version of SketchUp 2015.
271828183141592654 9 years ago
I think that this would be very useful for my needs too. Thanks!
bruce.desertrat 9 years ago
I"ve seen a version of this made with pipe clamp hardware, which makes closing the vise quick and easy: http://lumberjocks.com/projects/110041
Great idea; I like the design!
Stupid obvious once you think about it. Harbor Freight has 1/2" ones on sale for $6 apiece right now...Hmmm...
firefightermeyer 9 years ago
awesome. Just what I need!
