Introduction: Make a Motion Detector With Micro:bit and Octopus Kits
This article is from Tinkercademy: Make a Motion Detector.
Don’t like people sneaking up on you? Here’s just the right micro:bit project for you! In this course, we learn how to make use of the motion sensor, the moisture sensor as well as how they can be coded for.
Step 1: Goals:
1. Get to know the PIR Sensor Brick and moisture sensor.
2. Make something with a PIR Sensor Brick.
3. Make something with a Moisture Sensor.
Step 2: Materials:
1 X BBC micro:bit
1 X Micro USB cable
1 X Breakout board (Elecfreaks will soon publish a new fully compatible Breakout board for it. For more details, you can see: Elecfreaks Micro:bit Adapter)
1 X Mini buzzer
1 X Moisture sensor
Step 3: Procedure
Step 1:
After connecting one end of the USB cable to your computer, connect the other end to the micro:bit as shown in the picture. Connect the side of the micro:bit where the pins are located to the breakout board. Connect 2 wires to the buzzer.
The pin under the '+' sign on the buzzer (usually the longer one) will connect to the yellow pin on the break out board, while the other pin (usually the shorter one) connects to the black.
Step 4: Procedure
Step 2:
Plug in the buzzer to Pin 0 (the pins beside the number '0' on the breakout board) as shown on the left. Plug in the moisture sensor to Pin 3 as shown on the left. Plug in the motion sensor to Pin 1 as shown on the right.Make sure the colour of the wire of the buzzer and the ADKeyboard follows the colour of the pins on the breakout board.
Step 5: Procedure
Step 3:
Click on "Advanced" in the code drawer to see more code sections.
To code for our extra kit components (the ADKeyboard and the buzzer), we will need to add a package of code.
Look at the bottom of the code drawer for "Add Package" and click it to open up a dialogue box. Copy and paste this link into the "Add Package…" text field: https://pxt.microbit.org/50544-64675-33322-24641
Click on the search icon or press enter.Then, click on the Tinkercademy button.
Note: If you get a warning telling you some packages will be removed because of incompatibility issues, either follow the prompts or create a new project in the Projects file menu.
Click on Tinkercademy inside the Code Drawer to find our custom blocks for the various components in your kit.
For this project, we are going to use the blocks read value from moisture sensor and motion sensor.
Step 6: Procedure
Step 4
In this step, we will code the Micro:bit with Block Editor. We begin by coding a starting screen, by placing the "Show Icon" block under the "On Start" block as shown in the picture on the right.
This causes the icon to appear on the screen whenever the micro:bit is powered on.
Step 7: Procedure
Step 5:
Next, let's create some music using the moisture sensor values.
Select the "Play Tone" block under the "Music" code section and place the value of Moisture Sensor code block in it
The pitch can be adjusted by multiplying the sensor values by different numbers, as shown in the image on the left.
Step 8: Procedure
Step 6
Finally, make the buzzer sound when the motion sensor detects movements. The micro:bit will only show an icon on the screen if there is no movement.
This can be done by using a conditional (if-then-else) statement and inserting the relevant blocks in the appropriate spots, as shown in the picture on the right.
Succeed! You now have your very own Micro:bit motion detector!
