Introduction: Make a Self Opening Dustbin With Arduino
Self opening bin materials
Bin
Battery
Micro usb port
Ultrasonic sensors
Wheel
Motor
Servo
Switch
Arduino
Container
Battery
Micro usb port
Ultrasonic sensors
Wheel
Motor
Servo
Switch
Arduino
Container
Step 1: Placement for Ultrasonic Sensor
Get a marker and place the ultrasonic sensor on the desired position.
Draw the shape out and cut it out.
Get a glue and put it around the area,then glue it together.
Step 2: Getting the Control Set
Get a transparent plastic container, to allow you see the whole system well.
Cut a box at the top corner for the switch,
Place the arduino and the motor driver in it,alongside the battery e.t.c.
Cover it and glue it to the body of the bin
The code and the circuit diagram would be supplied below
Step 3: Add the Servo
Get a metal rod which can be bent and make a u shape with it.
Join the front to the bin,andthe other end to the servo .
Then connect the servo to the controls.
Step 4: Add Wheels
Get a plank.Cut it to a preferred size.
Attach it to the bottom of the bin,then place the 2 motors and wheels on it.
Step 5: The Connection
#define ENA 14 // Enable/speed motors Right GPIO14(D5)
#define ENB 12 // Enable/speed motors Left GPIO12(D6)
#define IN_1 15 // L298N in1 motors Right GPIO15(D8)
#define IN_2 13 // L298N in2 motors Right GPIO13(D7)
#define IN_3 2 // L298N in3 motors Left GPIO2(D4)
#define IN_4 0 // L298N in4 motors Left GPIO0(D3)
#include
#include
#include
String command; //String to store app command state.
int speedCar = 800; // 400 - 1023.
int speed_Coeff = 3;
const char* ssid = "NodeMCU Car";
ESP8266WebServer server(80);
void setup() {
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(IN_1, OUTPUT);
pinMode(IN_2, OUTPUT);
pinMode(IN_3, OUTPUT);
pinMode(IN_4, OUTPUT);
Serial.begin(115200);
// Connecting WiFi
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid);
IPAddress myIP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(myIP);
// Starting WEB-server
server.on ( "/", HTTP_handleRoot );
server.onNotFound ( HTTP_handleRoot );
server.begin();
void goAhead(){
digitalWrite(IN_1, LOW);
digitalWrite(IN_2, HIGH);
analogWrite(ENA, speedCar);
digitalWrite(IN_3, LOW);
digitalWrite(IN_4, HIGH);
analogWrite(ENB, speedCar);
void goBack(){
digitalWrite(IN_1, HIGH);
digitalWrite(IN_2, LOW);
digitalWrite(IN_3, HIGH);
digitalWrite(IN_4, LOW);
void goRight(){
void goLeft(){
void goAheadRight(){
analogWrite(ENA, speedCar/speed_Coeff);
void goAheadLeft(){
analogWrite(ENB, speedCar/speed_Coeff);
void goBackRight(){
void goBackLeft(){
void stopRobot(){
void loop() {
server.handleClient();
command = server.arg("State");
if (command == "F") goAhead();
else if (command == "B") goBack();
else if (command == "L") goLeft();
else if (command == "R") goRight();
else if (command == "I") goAheadRight();
else if (command == "G") goAheadLeft();
else if (command == "J") goBackRight();
else if (command == "H") goBackLeft();
else if (command == "0") speedCar = 400;
else if (command == "1") speedCar = 470;
else if (command == "2") speedCar = 540;
else if (command == "3") speedCar = 610;
else if (command == "4") speedCar = 680;
else if (command == "5") speedCar = 750;
else if (command == "6") speedCar = 820;
else if (command == "7") speedCar = 890;
else if (command == "8") speedCar = 960;
else if (command == "9") speedCar = 1023;
else if (command == "S") stopRobot();
void HTTP_handleRoot(void) {
if( server.hasArg("State") ){
Serial.println(server.arg("State"));
server.send ( 200, "text/html", "" );
delay(1);
NB:Download nodemcu_car.apk
#include
#include
#include
void setup() {
// Connecting WiFi
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid);
server.begin();
void goAhead(){
void goBack(){
void goRight(){
void goLeft(){
void goAheadLeft(){
void goBackRight(){
void goBackLeft(){
void stopRobot(){
void loop() {
delay(1);
