Make a Bow for Under 20 Bucks
Intro: Make a Bow for Under 20 Bucks
Make a hardwood bow with no special tools, setups or working space for under 20 bucks. Everything was purchased at Lowes.
STEP 1: Glue Together Wood
I went to Lowes and got these thing.
48"X1/2" Oak trim piece
24"X1/2" Poplar trim piece
bottle of gorrila glue
Stanley hand planer
bundle of jute rope (In the future, hemp would probably be better)
The hand planer from lowes turned out to be just the ticket for shaving down the bow arms to what I needed. Its only 6 bucks and its about 3"X1" big. Any bigger would probably turn out to be too unweildy. Any sort of wood glue would work really.. as a matter of fact, gorrila glue is probably not the best one to use. The wood was just some project wood or you could use trim wood too, I guess.
This is pretty self-explanatory, just make sure you get the glue more evenly spread than it is in this picture. Use sticks and rope as a clamp and the piece until its cured enough to release. This should actually take a few hours but since I'm really impatient, I waited for half an hour and then started carving. Dont do that, it just messes things up in further steps. Whatever you do, don't try bending the bow until the glue is dry either. This just makes them pop apart.
STEP 2: Plane Down the Wood
This is not really a hard step, but its pretty critical. Try to keep both sides the same and shoot for a shape like one in the diagram. I think The pictures can do a better job of explaining this than I can. So just ask me if you have any questions.
STEP 3: Add Handle
It might look a little complicated but actually is just a rope wound around the handle in a spiral fashion. I soaked the rope with glue too so it would stay there. This does a good job as a handle and a reinforcer for the two pieces of wood.
STEP 4: Cut the Ends
You need a place for the string to rest, so in two steps, cut notches at the ends like they are in the pictures. In the first step, cut the profile of the notches, and then smooth them out in the next step.
STEP 5: Bamboo Bows
Heres a picture of a bamboo bow that I made.
290 Comments
Wikiman12 12 years ago
How much is the pull weight? How heavy is the bow?
Thanks!
MichalW13 7 years ago
and now you're 17.. jeez
Master97865 12 years ago
Imcrazydude 12 years ago
Givver112 12 years ago
Xthinker 12 years ago
GeorgeP49 8 years ago
Hickory wood is the best for a bow. You can bend it double without breaking. I made one, using a draw knife. I used to climb hickory trees, lean out and ride them to the ground. Carefull not to get stuck half way down. Pick a skinny tree.
The Indians used hickory.
Bulinsky 9 years ago
can you please make a tutorial on how to make a compound bow? Thanks
gorth 9 years ago
This is not an Insructable rather an add for his site.
Billster36 9 years ago
What did you use for a bow string?
Darkst0fKnights 11 years ago
What is the draw weight of this bow? I am trying to make a 50 pound draw weight bow for myself but nobody ever puts the draw weight in their instructions
Theelvenarcher 9 years ago
i made a piramid longbow and it is 75 lbs at 28 this is probably 30-45
fun683 10 years ago
How do you bend the bow? Your tutorial doesn't say how to.
kmuggerud 11 years ago
Zetsumeimaru 12 years ago
La cacatua carmesi 12 years ago
