Introduction: Make a Key Hanger
What you’ll need
Plywood or any piece of wood
Image/s for decoration or paint
Command hooks,
Stapler (optional)
Wood glue,
Fishing line or string or wire,
Paint brush
Step 1: Paint or Collage
Take a piece of wood (mine is a plywood scrap from another project) and apply wood glue or any kind of glue suitable for wood, and wrap with a blank A4 sheet of paper (this size was good for me you may need more or less ok?) wrap it like a present and then leave it dry. I did this because I wanted my decorative picture to look clearer. I was afraid that if I didn’t it would appear transparent because it was a laser print and that’s not the best printing quality. Images cut from a magazine or from thicker paper won’t have the same issue. I also used some black trim for the edges. If you are not lazy like me you can paint it instead of collage it.
Step 2: Make It Hangable
Staple twice at the back so it creates "hooks". Do that before anything else because later you’ll attach the command hooks and it will no longer have a flat surface. If you don’t own a staple gun there is a brilliant idea that I saw somewhere to use a soda can tab. You simply remove the tab and screw the smaller hole on your surface. Make the attachments lower (nor top neither middle somewhere in between) than I because at the end mine was “bending” and I had to do it again.
Step 3: Decorate
Apply glue again and then picture/s of choice. A few days ago I was reading this blog (https://emsolo.wordpress.com/) when i found a picture I really liked. I asked the photographer if it's ok for me to use the picture, he said yes and now i have a beautiful piece of sky in my windowless hallway. Thank you Ed!
When dry, attach the command hooks, as many as you like. Mine had a sticker and also a screw because.. poor quality. Then it’s ready for hanging. i used fish line because I hanged it from an already existing nail that was far higher, and I wanted to appear like it was floating.
Happy hanging :-)
