Make Your Own Teepee
Intro: Make Your Own Teepee
Here's how my wife and I made our own Teepee that we use for camping and going to Rendezvous. It is very spacious inside with room for 6 adults plus our gear and we can have a fire inside for those cold nights. The building was pretty easy and quick and only cost about $150 in materials for the cover and liner
STEP 1: The Outer Cover
We bought 3 canvas tarps at Home Depot measuring 15 feet by 12 feet. ($25 ea.)
We then sewed the 15 foot sides together; at the end of this we had one big canvas that was 15 feet by 36 feet. Now comes some measuring and cutting, so take your time measure twice and cut once. We lay the whole thing flat in our yard so we could see it... Staring at the left side of the 36' side measure 10' to the right then drew a line 3' up then, on that same line do a 2' mark then draw a line back to the side making a rectangle that we will Call cut A-1. Do the same thing one the right side of the canvas we will call this rectangle A-2 (see diagram) * each square = 1'
Now cut out the two 10' by 2' sections and save these two pieces. Cut up the line to the 3' mark.
Take the two pieces that you just cut off and sew them together along the 2' side; move the piece to the back where it is sewn to the center of the 36' side making the center now 17' ( see diagram) *each square = 1'
Next find the center of the side you just removed A-1 and A-2 from and draw two lines 2' apart from the top of those lines 1 1/2' back to the center it will make a big M shape ... cut this part out ( see yellow area of diagram ) we the sewed a triangle piece of canvas where the bottom of the M where the smoke flap poles will go into.(see the teepee picture)
Its a good idea to reinforce all areas that end in a cut.
You now have your smoke flaps.
STEP 2:
Now for cuts B-1 and B-2 .
From the back left side measure 1 1/2' inward and 6 1/2' down to make cut B-1.
Do the same thing on the right side to make cut B-2 ( see diagram ) * each square = 1'.
Cut these out then take those two pieces and sew them together on the 15' side then take this piece and sew it to the middle making the 17' middle now 18 1/2'.
STEP 3:
Drive a stake in to the ground in the center of the M cut where the canvas would be if you had not cut it. Tie a rope to this stake and measure out 18' and tie a pen or maker at this point. Start at one of the corners and using the rope like a compass draw an ark all the way to the other corner this will make a half circle shape on the canvas as seen in the diagram ( there might be a little missing where A-1 and A-2 meet the big canvas but it shouldn't matter to much ...you can add pieces here if you want to make it all even.
Cut holes for the door (see diagram) then cut out the parts to make the door cover by sewing the two pieces together.
STEP 4: The Liner
The Liner of a teepee is very important if your going to have a fire, as it is what funnels the air so all the smoke will go out the smoke hole at the top. We made our liner by using two 15' by 12' canvases. We cut them in half making them four pieces 15' by 6'. We attached them to the poles inside the cover by wrapping a rope about 4'6" from the ground and then tied the liner to the rope with twine. We use rocks on the bottom of the liner to keep it down and keep out drafts.
STEP 5: Poles
There a few ways to get poles for your teepee. The cheapest way is to go to the woods and get them, another way is to buy them pre-cut. But the way we did it was to buy tree stakes and combine two 10' stakes together to make 20' poles that are easier to carry around on top of our Jeep. We got PVC that went over the poles (2 1/2" PVC) and cut them into 2' lengths . On one side we wrapped duct-tape around pole so it fit snug in the PVC then inserted it 1' and used three screws to secure it permanently to the pole then wrapped the other pole with duct-tape so it fit snug but could be taken apart when we were done, we did this with all the poles. when we put up the poles we used duct-tape were the take down was to make it less likely to come apart while placing the poles.
Each pole set consists of 3 tripod poles 2 smoke flap poles, 1 pre-measured lifting pole, and 10 regular poles.
STEP 6: Set Up
Steps For set up
1. Layout tripod poles.
2. Tie rope to poles
3. Raise tripod poles. Swing out North pole and place between 7 and 11. south pole will go between 4 and 8
4. Place pole #1 to frame doorway
5. Add poles #2, #3, #4, #5, #6, and #7 in the same crotch as #1.
6. Go around to back of tipi.
7. Add poles #8, #9, #10,and #11 in same crotch.
8. Wrap rope around poles.
9. Tie tipi cover to lifting pole at 18' mark.
10. Add lifting pole to space between poles #9 and #10.
11. unwrap tipi around poles with two halves meeting at door opening.
12. Using wooden lacing pins join tipi halves. (see diagram)
13. Adjust poles until tipi looks good.
14. add smoke flap poles
15. Using wooden pin fasten door on second set of holes above door.
STEP 7: All Done
There are many ways to put up a teepee (tipi) on the internet so look around... the main thing I wanted to show in this Instructable was how we made the cover. You might want to make a small version first to try it out before making a big one (We made one for "Barbie" before we made our big one.) Have fun!
49 Comments
Adrianpawli 4 years ago
MikeyS12 3 years ago
warren720 5 years ago
Thanks, Ryan
jessyratfink 5 years ago
- Pin the edges you're sewing together VERY well. It's so heavy that if it's not pinned and pieces start to move, you'll wind up sewing really crooked. :)
- Use a heavy duty sewing machine and a denim needle. Cheapie plastic machines may not be able to handle the weight of the tarp.
- Don't let the excess tarp hang down - hold in in your lap. If you let the tarp hang down while sewing, it can pull at your stitching and cause uneven sewing.
KatieW116 6 years ago
What is the diameter of this tipi? I want to follow this pretty exactly, so I dont have to do much of the math myself (I'm very bad at math), but were wanting an 18ft diameter at least.
Also, how did you attach to the ground? Did you later add some small loops for spikes?
MikeyS12 6 years ago
Hi Katie, to be honest I have no idea on the diameter,it was just what it was when we finished. We did attach web looping around the bottom right about where each pole was then put tent stakes through the loops to keep it down
solitary man 6 years ago
Thanks! Great Instructable! I want to build a tips mysel
the tat2artist 6 years ago
I say Do it! also the size is up to you make it smaller if your "solitary" LOL
LadyLTaylor 6 years ago
Hi, I hope your still out there..... I am wanting to make this teepee for a rendezvous. I think I have done all the math right. When you made this teepee what did the foot print end up being on your space? Did you use a ground cloth around the outer edge (ie. away from the fire) and how tall was it in the middle?
Thanks so much!
We used a ground cloth where we slept. It was about 15 feet high in the middle...as far as the foot print it was as big as the bottom of the poles I couldn't tell you exact size but we once had 10 people inside during a Rendezvous all drinking and telling stories and we were not cramped.
Kuffar 9 years ago
For those that seem to have their panties in a wad, over the flag. Count the stripes, please. You will notice that there are more than 13 (18 by my count). That is how many colonies, and thus stripes, are on the U.S flag. The author doesn't point this out, but it is O.K. to use striped material, any way you deem fit.
Very nice ible. I've been wanting to make a tipi for years, just haven't gotten one of those rountuits, yet.
lm5392 7 years ago
I don't know where you got your flag, but if it has more than thirteen stripes, it is not a proper flag and probably made overseas. I have several, including one from a veteran's funeral, and all of them have seven red stripes and six white stripes with a red stripe at the top and bottom and a red stripe separating each white stripe. Also, the blue rectangle contains 50 stars, for each actual state, no star is included for D.C., nor any provinces. The stars are in rows, starting with six in the top row and five in the second, then alternating six and five for a total of nine rows to make 50 stars.
the tat2artist 7 years ago
lm5392 7 years ago
sorry, I didn't realize you were talking about their bunting, not the American flag.
emkh66 7 years ago
hi! i'm looking forward to making this instructable and am planning to do so for my wedding night! i would like some advice on the sewing- did you hand sew or use a machine? what type of thread? i have a standard sewing machine with a short arm so i am concerned about it fitting all this fabric. thanks so much!
emkh66 7 years ago
i'm finally getting into this and have a second question for you. i've gotten as far as cutting out the 'm' shape but am unclear what you mean by the next direction: "we the sewed a triangle piece of canvas where the bottom of the M where the smoke flap poles will go into.(see the teepee picture)" i'm afraid whatever this piece is in not that clear to me in the teepee picture. thank you!
I was trying to explain where we put the smoke poles if you look at the teepee photo you will see there is a little pocket on the ends of the flaps that holds the poles up... I hope that helps
emkh66 7 years ago
Ah, I see. I don't seem to be able to zoom in on that photo so yes, that helps!
What I think I'm still confused on in that phase of the instructions is the utility of that 'm' shape cut. Is the 'peak' of the 'm' where you made another little pocket and placed your lifting pole?
