Makedo Cardboard Christmas Tree: 2018 UPDATE
Intro: Makedo Cardboard Christmas Tree: 2018 UPDATE
Create your own Makedo Cardboard Christmas tree these holidays. All you have to do is download the template file available here on instructables and go to www.make.do for some Makedo cardboard construction tools.
STEP 1: Makedo Christmas Tree Template!
Download this template file (pdf below) to start making your Makedo Christmas tree. :)
STEP 2: Cut
Referencing from the downloaded template, measure and cut out the cardboard triangles. You should have a total of 16 triangle panels.
STEP 3: Score
Where the perforated line is illustrated in the template, lightly score the cardboard with the tip end of the safe-saw.
STEP 4: Punch
Use the Makedo safe-saw to punch holes in each triangle panel as shown in the template.
STEP 5: Fold
Fold along the creased line. Repeat steps 1-3 for the remaining triangular panels.
STEP 6: Build
Each module uses four identical triangle panels. Place the flap of one triangle over the edge of the second and align the holes. Screw in place using Makedo cardboard construction tools.
STEP 7: Connect
Fold in the flaps underneath and screw the corners together to complete the triangular module. You should have 4 modules. 1x A, 2x B & 1x C.
STEP 8: Stack
Position the triangles on top of one another in the following order (from bottom to top): B - C - B - A.
STEP 9: Decorate
Draw on the cardboard, attach DIY Christmas ornaments that you've made yourself or find other interesting ways to personalise your Cardboard Christmas Tree.
STEP 10: Complete
Your Makedo Christmas tree is complete! Find a cozy corner or a warm spot by the fire (not too close!) where your tree can bring festive cheer to your home.
Share and upload your creation: go.make.do/upload
...or to Pinterest and Instagram.
Tag your photos: @makedo #mymakedo #cardboardchristmas #cardboardchristmastree
Discover more cardboard creativity at www.make.do
STEP 11: Makedo Christmas Tree in the Making
Stop motion video of the Makedo Christmas tree at Makedo HQ!
39 Comments
Angelina44 8 years ago
what are the measurements for the side flaps on all triangles
Zaliyah 8 years ago
makedo-able 8 years ago
Hello Zaliya.
Do you mean a light inside the tree like "Boniwood" shows in the image posted here in the comments? It looks like this was achieved by punching many holes in the cardboard surfaces, and then placing a desk lamp inside.
Just take care not to put any heat sources (hopefully it's an LED lamp!) too close to the cardboard, and it should work nicely.
Hi Angelina.
The Makedo Cardboard Christmas Tree can be scaled to suit the materials you have available. In the template that we have provided here (see the image at the beginning of Step 1) the measurements are a suggestion, not a rule - you can choose your own proportions and the design will still work. You just need the panels to be identical in size for each triangle.
The side flap does not need to be a specific size, the only requirement is that you have enough material to punch and then scru through when folded under the adjoining panel. About 2 inches/5cm should work nicely.
ElodieD3 8 years ago
Merci d'avance.
StaceyD1 10 years ago
made on my silhouette loved it thanks!
Dsuer1 9 years ago
dtouchet2 9 years ago
What is the width at the widest part? i have limited space and wanted to do something like this instead of a traditional tree.
hasan.bobo.75 10 years ago
loved it thanks
ramdiandrea.diaz 10 years ago
linuxnewbie 10 years ago
I suspect this would also work with McGroovy's connectors or even oversized envelope clasps
lemondedis 12 years ago
porcupinemamma 11 years ago
makedo-able 12 years ago
gloria yazbeck 11 years ago
softenersreviews 12 years ago
judaloo29 12 years ago
The idea is that you find your own materials locally, close to your home. It may be cardboard boxes or sheets, reclaimed packaging or even old advertising panels. You can then make your own tree following these instructions along with Makedo parts to connect it all together.
We suggest using the Makedo Kit for Three for this creation.
It's a table-top version of the coolest DIY tree in town.
