Introduction: Making Enlargements in the Darkroom
This will walk you through the steps of making a 5x7 enlargement in the darkroom with black and white film.
(See THIS VIDEO about enlargements)
- Negatives
- Photo Paper
Step 1: Setting Up
Complete this step BEFORE turning on the enlarger. Make sure you view all 7 photos in this step.
- Use the handle on the left side of the enlarger to raise the enlarger head. Remove the negative carrier. (This is the same on both enlarger models)
- Insert the negative into the negative carrier shiny side up and place the carrier in the enlarger.
- Close the negative carrier and return it to the enlarger making sure it is centered and inserted all the way (see images).
Step 2: Turning on the Enlarger
•Turn the enlarger on (push “focus” button on timer)
•Set the timer for 2.0 seconds
•Place the easel under the enlarger
(See THIS VIDEO for the steps to set up the enlarger)
Step 3: Adjust the Height & Focus
•Adjust the height of the enlarger and the position of the easel until the image is slightly larger than the 5x7 space on the easel
•Focus the image on the easel with the grain focuser (have the aperture all the way open and the safety filter out of the way)
(See THIS VIDEO for setting up the Beseler enlargers)
Step 4: Aperture
•Close the lens down 2 stops to aperture 5.6 and cover with safety filter
Step 5: Contrast Filters
Turn or insert on the Contrast Filters needed for the image.
Talk to your teacher if you are not sure what setting or filter you will need
For the Beseler with 3 filter dials:
- Turn the Magenta/Pink knob to the desired setting
- Flip the lever on the right side of the enlarger head up to Filtration
For the Beseler with 1 filter dial:
- Turn the dial to the desired setting contrast level (1-5)
(See THIS VIDEO for information on setting the contrast filters)
Step 6: Making the Test Strip
- Cut a 5x7 in half for the test strip exposure and place it in the easel (shiny side up)
- Cover all but about 1 inch of the test strip with cardboard
- Turn the enlarger off (push “focus” button on timer) and swing the safety filter out of the way
- Push the “run” button to expose
- Continue making 1 inch exposures all the way across for 2 seconds each
(See THIS VIDEO on making the test strip)
Step 7:
•Process as usual to determine the correct exposure
•Make the final enlargement on 5x7 paper
•Make sure the paper is lined up in the easel so the edges of the paper are against the tabs that stick up on the bottom and left side edge of the 5x7 position
