Introduction: Making Safe and Smart Lock 2 Levels
About: We make clever things from cardboard, ice cream sticks, ....Discover how to make crafts by yourself. Learn how to carry out safety science projects including things like robots, water bottles, windmills and mo…
Hi. This is our smart lock box
An extremely strong safety lock box
It helps you to store your personal property
Do you know how it works?
Check out my guide below
I hope you like it. If you like it. Please vote for me
Thanks. Let's make it :))
Note : You can watch the video to understand the steps to do!
Step 1: YOU NEED
👉 You need:
- Cardboard
- Ice-cream stick
- BBQ bamboo stick
👉 Cardboard Measurement:
(cm = centimeter) 22cm x 17cm = 2 Pieces
7,2cm x 4cm = 1 Pieces
8cm x 4cm= 1 Pieces
17cm x 4cm = 1 Pieces
21,5cm x 4cm = 1 Pieces
12cm x 1cm = 4 Pieces
8cm x 3cm = 2 Pieces
5,5cm x 3cm = 2 Pieces
27cm x 25cm = 2 Pieces
27cm x 29,5cm = 2 Pieces
29,5cm x 26,7 cm = 2 Pieces
Step 2: Prepare
Prepare 3 sheets of a4 paper
Colors you have custom tags
Step 3: Roll
Roll the first A4 paper (pink paper)
After the roll is finished, place it on the second A4 paper and curl up (Blue paper) Do the same with the other paper(white paper) Cut 2 short sections of the last A4 paper roll (white paper) ( fifth photo)
Step 4: Draw Circle
Draw and cut three circles with a radius of 3.5 cm.
later. Create a small hole in the circle to create a rotating mechanism Do so with the remaining 2 circles
Step 5: Circle
Prepare 4 hardcover 2cm x 1cm in size
Note: there are three circles the first circle and the third circle paste it with a small cardboard
The second circle in the middle, paste the small cardboard on both the front and back Look at the illustration for easy visualization (first image).
Step 6: Mechanism of Action 1
Place the white paper we cut earlier into the first and third circles
After that, put them on the blue paper roll
The remaining circle is placed on a pink scroll
then put them together and test it
Step 7: Prepare
Prepare a rigid sheet with the pattern as shown
Cut off the highlighted part in red
Step 8: Cardboard
Cut 4 sheets of 12cm x 1cm cardboard
Next take 2 cardboards and paste them These cardboards are for pasting around the box. Please paste it with hot glue
Step 9: Paste
Put the spindle part in
and cut off the excess(fourth photo)
Step 10: Lock Up
Draw and cut 3 circles.
The first circle has a radius of 3.5 cm The other two circles have a radius of 2.5
Step 11: Circle Length
Here, I will show you how to calculate the length of a circle.
It is calculated using the formula: C = 2πR
Please save this calculation.
not just today.
Is not just part of the steps to make this box.
It can calculate every circle length of every object
Step 12: Hand Lock
Take the outer thin cardboard and stick it on the circle we just cut
Create a small hole in the circle Finally, paste it all in the box
Step 13: Mechanism of Action
Watch the video below for a better understanding. This is the time for you to consider the password
Step 14: Lock Box
Make the front of the box with a cardboard box measuring 22cm x 17cm.
Stick two small cardboard sheets and place it in the box of the box
After you finish this section, you have finished half the work
Step 15: Hold Mechanism
Prepare 2 18cm x 4cm cardboard sheets and glue them together (1st photo)
The handle for the box( fourth photo)
Step 16: Second Lock
Second lock
Prepare a rigid sheet with the pattern as shown and some small cardboard needed
Let's stick them together. Then put it on the box
Watch the video below to understand
Step 17: The Font of the Box
Make a cardboard box big enough and have holes. Put the lock in and make it open
Step 18: Final
Final. Make a storage box. and put the lock box in
Step 19: Password
Set a password for the box. You can customize the password of the box to your liking
Step 20: Finished Product. Let's See the Finished Product
I hope you like it.
If you like this safe Lock. Vote to help me. Thank you very much :)))
Thank you very much. Have a nice day ! :))))
