Introduction: Making Triple Beds Safer
About: I am bored wombat living in South Eastern Australia. https://bored-wombat.yolasite.com https://bored-wombat.webnode.com
This Instructable shows how you can make a multi-level bed safer.
You might be staying in a hotel where there are multi-level beds. You can fall on the floor one night and hurt your head. Keep in mind that the hotel manager might not approve of this. However, the hotel might not want to pay for medical bills if you fall when turning over in your sleep.
You might need scissors to cut the rope if it is very long. I did not use any scissors because my rope was not that long. You will need at least 5 metre rope. I used a thin rope and thin rope is the best solution in my opinion. A thick rope might not fit through in between the joints. You do not have to use the rope pattern that I used. You can try other patterns. Then you can use a thicker rope. You can also use: metal wire or sticky tape. You can make a small needle from metal wire and use it to pull the thin rope through the metal joins and the third bed above. You can tie the rope in any way that you like or just spin/wind many tuns around the metal bed bar. If you are using a metal wire than you will need pliers.
