Introduction: How to Make a Manivelle Water Gun
About: Founder of Capstone-X | Electrical & Communication Engineer💡
Manivelle (Crank) Water Gun is a new design of water guns that is characterized by the attractive view and in the fun that is created during water play. This water gun is a 3D printable object, so in this instructable, you will follow the designing of the different parts of the manivelle water gun.
This water gun depends on the mechanical motion of the hand to operate.
#TinkerMechanical
Step 1: Designing
Tinkercad is a very easy application to design a 3D printable object.
You can view it on Tinkercad: https://www.tinkercad.com/things/dspXTLUMqDF#
You can view it also on my minifactory: https://www.myminifactory.com/object/3d-print-wate...
In the upcoming step you will use a 3D Printer to print the different parts of the water gun.
Note: In my water gun I print each part separatly and then I gather them up using a glue gun because of the range of printing of my printer.
Step 2: The Fan
Download the file and print it.
Stick this fun in the screw through the center of the base part.
Step 3: The Base
This part where the water circulate to be shoot out.
Step 4: The Cover
This part that covers the the base part of the water gun.
Step 5: The Head
Step 6: The Junction Part
This part that connect the handle with the hole body of the water gun.
Step 7: The Handle
Step 8: The Screw
Note: you can replace the 3D printable screw by a metallic one to maintain the strength and the durability of the water gun.
Step 9: How It Should Be
View this 3D design to gather up the different parts.
Step 10: Gathering
Gather all the parts together by sticking them using a glue gun.
Step 11: The Final View
Step 12: Have Fun !!
