Introduction: Men's Shirt Skirt
Make this skirt from two thrifted men's shirts and add a real sewn waistband for a professional look.
Step 1: Watch the Video Tutorial!
Step 2: You'll Need
Two men's shirts
Sewing machine
Matching thread
1/4 yard iron on interfacing
E-6000 Stitch Less Iron On Glue
Scissors
Ruler
Straight pins
Iron
Step 3:
Cut the front of the shirt along the side seams, across the front right under the collar band and down the side seam again
Cut out the back of the shirt removing the stitched side seams, across the upper back and down the side again
Do this to both shirts
Cut off the tail and up the center back of both shirt backs
Cut a straight line from the hem of the shirt to the shoulder
Step 4:
Pin the two back pieces from one shirt to the sides of the front of the other shirt and stitch together using 1/2" seam allowance
*This is the skirt front Cut off the button and buttonhole plackets on the other shirt, pin and stitch together to create one piece
Pin the back pieces from the other shirt to the sides of this piece and stitch together using 1/2" seam allowance
*This is the back of the skirt Stitch the front and back together to create the skirt
Step 5:
Press all seams together and zigzag over each one to finish the raw edges
Gather the waist of the skirt to your waist size
Cut the sleeves apart at the seams, remove the cuff and iron flat
Measure a 3" wide strip down the center of each sleeve (this will be your waistband)
Stitch the two 3" wide strips together to create a long 3" strip
Measure your waist, add 1" and cut the long fabric strip to that size (if your waist is 32", then cut the strip 33")
Cut an identical piece of iron on interfacing and iron it to the strip
Step 6:
Finish one edge of the waistband with a zigzag stitch
Pin the raw edge of the waistband to the gathered waist of the skirt (right sides together) leaving a 1/2" overlap on both sides
Stitch the waist band to the skirt using 1/2" seam allowance
Fold the waistband over (right sides together) and stitch the 1/2" overlap on each end of the skirt
Cut the corner at an angle and flip right side out
Press the waistband into place You will now be hiding the gathering of the skirt inside the waist band
Step 7:
Stitch over the waistband, trapping the gathering inside and catching the finished edge of the waistband on the inside of the skirt
Add a buttonhole above the line of buttonholes in the center front
Stitch on a button
Hem the skirt by turning the hem 1/4" and then 1/4" again *This is called a turn and turn hem
If you don't want to hem, you can always use E-6000 Stitch Less Iron on glue and iron your hem in place
