Introduction: How to Make a Metal Lathe Knob Turner
About: Just a normal guy trying to make it in life .Good paying job but mindless sometimes .I enjoy making things in my garage to keep my mind going .. Its fun making something new but its more fun taking something…
This is my finished  ball and knob turner. You can make knobs out of any material you want . Brass,plastic,aluminum,steel , wood .This style of turner i can create a ball  up to 1 1/4 inch round.
Step 1: Ball Turner Base Plan
Here are the plans for the base of the ball turner which goes into the cross slide  of the lathe .
Step 2: Machining the Base
pic#1 shows the 1 1/4 inch height i have to maintain and the end of the project.
#2shows milling the edges square
#3 shows milling the a edge slots that fit in the cross feed ..
#4 shows the top milled flush with the cross feed and it fits very snug.
Step 3: Hub for Turner Rotor
Step 4: Ball Turner Rotor Plan
Here is the detailed plans for the  cutter rotor
Step 5: Making the Rotor
pic #1 shows the rotor being drilled through with a  1/4 inch tap drill  and will be threaded  1/4x20
 #2 Shows boring a hole  1 1/4 wide by 3/8's deep to fit a bearing.
#3 shows the rotor with the 1 1/4  outside diameter  x 3/8's thick  x 1/2 inside diameter  bearing press fitted flush to the bottom edge.
Step 6: Milling the Rotor
 pic#1 shows milling the center of the rotor which will help the cutter slide on center of the rotor.
#2,3,4  Show milling the rotor to the correct size for  clearance   to cut the knobs
Step 7: Ball Turner Bit Plan
Here is the detailed plan for the turner bit
Step 8: Making the Cutter Bit Bracket
pic #1 , 2  shows milling the stock to make sure the edges are square
#3 Shows the milled slot for the carbide bit will sit.
#4 ,5  show the bracket milled to the proper thickness.
#6 Shows the 1/4 inch milled adjustment slots .
Step 9: 1/4 and 3/8 Inch Threaded Knob Arbors
 Here is the plan for the arbors for different size threaded knobs.
Step 10: Finished Video of the Knob Turner Turning a 1 '' Aluminum Knob
