Introduction: How to Make a Metal Lathe Knob Turner
This is my finished ball and knob turner. You can make knobs out of any material you want . Brass,plastic,aluminum,steel , wood .This style of turner i can create a ball up to 1 1/4 inch round.
Step 1: Ball Turner Base Plan
Here are the plans for the base of the ball turner which goes into the cross slide of the lathe .
Step 2: Machining the Base
pic#1 shows the 1 1/4 inch height i have to maintain and the end of the project.
#2shows milling the edges square
#3 shows milling the a edge slots that fit in the cross feed ..
#4 shows the top milled flush with the cross feed and it fits very snug.
Step 3: Hub for Turner Rotor
Step 4: Ball Turner Rotor Plan
Here is the detailed plans for the cutter rotor
Step 5: Making the Rotor
pic #1 shows the rotor being drilled through with a 1/4 inch tap drill and will be threaded 1/4x20
#2 Shows boring a hole 1 1/4 wide by 3/8's deep to fit a bearing.
#3 shows the rotor with the 1 1/4 outside diameter x 3/8's thick x 1/2 inside diameter bearing press fitted flush to the bottom edge.
Step 6: Milling the Rotor
pic#1 shows milling the center of the rotor which will help the cutter slide on center of the rotor.
#2,3,4 Show milling the rotor to the correct size for clearance to cut the knobs
Step 7: Ball Turner Bit Plan
Here is the detailed plan for the turner bit
Step 8: Making the Cutter Bit Bracket
pic #1 , 2 shows milling the stock to make sure the edges are square
#3 Shows the milled slot for the carbide bit will sit.
#4 ,5 show the bracket milled to the proper thickness.
#6 Shows the 1/4 inch milled adjustment slots .
Step 9: 1/4 and 3/8 Inch Threaded Knob Arbors
Here is the plan for the arbors for different size threaded knobs.
