Introduction: Methods to Control Pests
Do you have the problem of pests in your house too? Well You are not the only one. I have a method to solve this problem of pests. Instead of calling the professionals to put some medicines, which eventually wear out, use the methods that i have written in this Instructable.
Step 1: What Type of a Pest Is It ?
There are many types of pests which enter your house. The pest that are most often found are as followed.
Ant, Bed Bugs, Cockroach, Beetles, centipede, earwigs, Crickets, Flys, Moths, Red Spider, Silver Fish, Woodlice, Termite, Weevils.
Step 2: Remove Water.
Everything living thing in this world needs water. Like us the pests also need water to survive. These pests go looking for water, for a chance of survival. So, you need to keep every area in your house dry. For ex: The washbasin, The washroom, The kitchen.
Step 3: Close All Kinds of Holes Through Which the Pest Could Come Inside Your House.
Yes, there are so many places in your house through which pests could enter. Seal the potential gaps through which the pest could enter.for example: the window frames, the gap between the door and the doorframe.
Step 4: Killing the Pest With Chemicals
Mix the following product with water and pour them to a place where you see them often.
If you are scared that children may go touch that chemical, add a cream base to it.
Attractants Attract pests
There are many other types of methods through which pest can be controlled.
Step 5: If None of These Works.
Finally, if none of these steps work call the pest control people to help get rid of the pest control for some time.
