Introduction: Microwave Transformer Fun
Warning I take no responsibility for any injuries obtained.
You are doing this at your own risk.
This is to give you the basic idea of wiring for a transformer.
I Will Be using a Microwave transformer.
Step 1:
You Need to find your self a transformer.
My choice is a Microwave tranformer.
You Will also need some tape, wire, switch, fuse and a wall plug
The  switch sould be able to take 10amps at 240 AC.
These can all be found in a microwave.
Step 2: Primary Coil Connection
Stat wiring Need to wire the phase wire from the plug to the switch and the neutral to the fuse.
These wires will now go to the Primary coil of the transformer.
Step 3: Secondary Connection
Now we needt to conect the Eath conection from the wall plug to the base for the transformer, We will add a secound cable from the base of the transfomer, This will act as the common Neutral for the high voltage side.
Now we  will add a connection for the phase of of HV side.
Step 4: Have Fun
Turn On the Switchs and you will hear a slight hum, Good sign now get the to Hv wires and touch them together to draw an arc if this works well done.
