Introduction: Milk Paint Hack
Traditional milk paint comes in a powder form that has to be mixed with water. With this creative misuse, I'm showing you how to mix milk paint fast and efficiently using none other than two items from the kitchen: a milk frother and a coffee filter.
If you've ever had to mix only a small amount of milk paint - or you're using it as a watered-down stain - you'll know that mixing it can be a challenge. For a project I just completed, for instance, both of those conditions were met: I literally only needed to mix a few tablespoons of milk paint to stain a few boards. It's not possible to use a blender, as I normally would for large projects, because there isn't enough liquid volume to come into contact with the blade and mix it properly. Hand mixing is slow and stubborn lumps can prevent a smooth mixture.
To resolve those problems, give my mixing hack a try. It's fast, clean up is a breeze and it's splatter proof!
Watch the video to see how quick and easy it is!
Step 1: Milk Paint Supplies
For the next two steps, you'll need milk paint powder, a coffee filter, milk frother, water, a mixing cup (preferably clear), a mixing spoon, a paint brush and a wooden craft stick.
We use Homestead House milk paints; the colour you see used in the next step is 'Coal Black'. I use a dedicated frother for mixing milk paint that is separate from the one I use in the kitchen. Milk paint is all natural but I like to keep my craft tools separate from my kitchen tools.
A clear plastic cup for mixing is best so you can make sure there are no dry spots on the bottom of the cup. For small quantities, I use a tablespoon to measure the water and milk paint powder. Eventually, as you get used to mixing the powder, you will be able to eyeball the quantities of each but if you're just beginning, it's helpful to measure out the water and milk paint.
The coffee filter is the trick to keep the milk paint from splattering as you mix; the next step shows you how to prepare and use it.
For small projects, I generally use a chip brush to paint. For larger projects, I like to use a Staalmeester as you can see on the bottom of the picture.
The craft stick is essential to mix the milk paint occasionally as you work; the pigments tend to settle as you work away on brushing on the paint.
Step 2: Prepare the Coffee Filter
The spot where I paint in my craft studio is pretty confined so it doesn't take much for splashing to occur when mixing small batches of milk paint using the milk frother.
This handy trick will prevent milk paint from splattering out of the mixing cup. To start, take a coffee filter and fold it up into quarters. Use scissors to cut a small hole right at the pointy tip.
Unfold the coffee filter and cut a straight line up to the hole you just cut in the middle. The hole is necessary so that when the frother is on, the filter won't catch and get caught around the spinning spindle of the milk frother (trust me, I know this from experience).
After the water and milk paint are added to the container, drape the filter over the top of the cup then insert the frother through the hole in the middle. Overlap the filter at the seam and now you're ready to turn on the frother without fear of splashing! Disaster averted!
More about mixing the actual milk paint in the next step.
Step 3: Mix the Milk Paint
I mixed up a small batch of milk paint using Coal Black. Instead of the usual ratio - 1:1, I diluted it with more water to make it more like a stain (about 3 parts water to 1 part milk paint powder).
For small batches like this, I use the tablespoon to measure the water and milk paint. I add the water to the cup first and then the milk paint (although some people swear by doing it the other way around).
Put on the coffee filter as described in the previous step. Rest the frother on the bottom of the container and apply pressure. Turn it on and lift it up ever so slightly to mix. Work the powder into the water in this pouncing manner for a maximum of 20-30 seconds so it doesn’t over-froth (if it does, there's a fix for that too!).
Remove the filter and let the milk paint sit for a few minutes (go do something else). This will allow the water to absorb fully into the powder. Give it another quick mix with the frother - or you can simply use a wooden craft stick (which you should also use to periodically mix the paint because the minerals will settle as you paint).
If you find that the paint got too frothy, you can let it sit for a while so the bubbles disperse or skim them off and discard them. But who has time to wait when you're excited to get started? I skim the bubbles off.
Clean the Milk Frother
Submerge the frother in a cup of water and turn it on to rinse. Give it a shake and let it dry so it's ready to use next time. As I mentioned in the supply list, I keep my milk frother exclusively for milk paint use.
Step 4: Use Your Milk Paint Stain to Create Faux Barn Board!
There are many uses for small quantities of milk paint. I painted our 'Partners in Grime' galvanized metal planter and a mini adirondack chair - both of which can be found on Instructables!
I also developed a faux barn board technique that uses milk paint as a stain. We'll have instructions for that coming up in a future Instructable so stay tuned for that one. Check out the last picture to see samples of what you'll be able to accomplish!
If you haven’t already subscribed, you can follow us right here on Instructables or via on our own website. You can also follow us on Pinterest, Facebook, our YouTube channel and on Instagram.
Step 5: BREAKING NEWS!
Birdz of a Feather is excited to share that we've been nominated for an Amara Award in the Best DIY & Home Improvement (International) category. Voting goes until September 19th, 2018.
Show us some ❤ by casting a vote! This year one of the blog award sponsors, Leica, will be giving away a SOFORT instant camera to one lucky voter, so it's a win-win! Your vote will help get us to the shortlist :)
