Introduction: Minecraft Instructables Robot
I don't know about you but I love the Instructables Robot. So I decided to make one in Minecraft. Its pretty big and it's hollow. I converted the inside to a house. I hope you enjoy this instructable. Don't forget to vote.
Step 1: What You Need
What you need is
10 Red Wool
28 light grey
30 black
662 Yellow
10 Red Wool
28 light grey
30 black
662 Yellow
Step 2: Feet
Make 2 platforms on the ground each 2 X 3 with 8 blocks between them in light gray wool. Now (following the pictures) make the circle ish these are the feet.
Step 3: Legs
(For this whole instructable it is a good idea to follow the pictures) Now for the legs go on top of the feet and stack up 4 blocks in yellow wool then 1 in black and 2 more in yellow. They should be hollow. These are the legs.
Step 4:
Now make a platform on top of the legs in yellow wool it should be 8 long and 17 wide. (just follow the picture)
Step 5: The Middle
Then make walls in the platform that go up another 11 blocks and put a roof on it. That Is the middle.
Step 6: The Head
Now do as in the pictures and make a head 5 X 8 in yellow wool. that's the head.
Step 7: Details
Put 2 red eyes on the front 2 blocks in between them. then to blocks under the eyes make a black line that is 4 long for the mouth. Now 2 blocks from the top make 3 squares that are 2 X 2 and use light gray wool. Under the gray squares make black line that is 6 blocks long.
Step 8: Antenna
For the antennas on the side of the head make a 3 X 3 square with red wool then a red block in the middle and one on the middle block. Then repeat that step for the other side. Then add 2 black wool blocks on each side for the finishing touch.
Step 9: Arms
for the arms go down 4 on the sides when you reach that block start going out and go out 8 blocks and do this 4 times 2 make a 2 X 2 thick arm. Then repeat for the other side.
Step 10: All Done
Now you are done. I a extra step and made a house inside of it by just putting ladders in the hollow legs and then in the body I put pictures in it and a bed it's pretty sweet. Well I hope you enjoyed this instructable. And don't forget to vote.
